Some other Source Follower Configurations
iko
Ex-Moderator
Joined 2008
I see. In simulation this topology does very well, in my opinion. The best I could tweak it to is like you see in the attachment. I still wonder though, how this translates to real life.
If you use the standard DAO, then in theory you can use any constant current source. It so happens that the cascoded LU1014 is a very good one. But more importantly, I used them because they allow identical thermal drift on the upper and lower halves, thus guaranteeing near-zero DC offset. This is the same argument for using my 2SK372V heatsink for the current sourced loaded source follower, or the "B1".
In the TCS version, you are actually using the lower device as well to provide current. Thus the linearity of the lower device becomes equally important. And I certainly would not recommend you to use a mosfet there.
Patrick.
i m now listening to my newly transformed amp with grado sr225 and i noticed an increased in soundstaging and smoothness. since my source for now is only a modified x-fi and the 681r is a cheap trimpot, i cant comment any further than that.
also i use a clclclclclc composed of custom wound 15mh inductor and 10mf caps ( overkill? :)) as psu and the sound is much better than sigma22 except for bass and depth of scene.
thanks patrick for the help so far
Joined 2006
Hi EUVL,
I'm finishing my DAO build and i've just found an inconsistency between the schematic ( post 309 )and the PCBs of post 15 and 47...
The top ( in the schematic ) J511 connects to the +24v line but in all PCBs i've seen in this forum it connects directly to IRFP240 Drain.
Could you clear this up for me please ?
There are very few who noticed that. ;)
In theory it is better to connect the current diode (J511) to the positive rail.
In that particular layout, it was a bit difficult, so I took the next best point that was more convenient for the layout, which was the drain of the cascode MOSFET. Because of the use of the current diode, this does not make much difference.
However, since the J511 is now obsolete, and you would probably want to use something like the E452 as a replacement, you can conveniently connect it back to the positive rail. In fact, this is what we are doing right now (in designing a proper PCB for the DAO TCS).
Patrick
