The important part is:
- Have you removed the USB HUB?
- Are you using Amanero's latest CPLD ver 1080 & CPU ver 1080 firmware?
Shorting those 2 pins... USB out, USB in...
Looking for device
Please erase the device.
I'm unlucky...
Looking for device
I'm unlucky...
Not sure what you shorted (!!??) - you have to complete this procedure
to the letter.
Yes I have follow it. I cant seem to be able to erease the flash whne following the inststruction. Shorting = contact betwen pads.
So I do it for 1 second (and many other durations...)
Go and iintiate update and get the answer - Please erase the device which I intepret as the pad shorting did not succeed...
Hi!
I'm not a DAC expert like most of you here in this thread, so I would like to ask:
Can someone explain to me simply and clearly how to be connected this DAC to a "USB to Spdif" converter ?
(It is a CM6631 converter. I have a Spdif out RCA connector in the converter and a coax cable to the DAC)
If I use +/-DC, which pin is + and - ind the power input connector?
I got the board, but without any detailed user guide, or manual.....
Thanks in advance!
Tyimo
Where is this manual???There will be example schematics in the manual.
Thanks in advance!
Tyimo
As has been said in the Vendors Area thread Soren is working hard to finish the manual... should be just a matter of days .
Also check the thread for some possible information on how to connect things.
Thanks!
I thought it will be "plug and play" with a normal spdif coax source....Up to 24 bit / 384 Khz input from SPDIF, I2S and USB (via USB to I2S interface board), with isolation on the I2S interface.
Thanks!
I don't believe the board was ever positioned as such. At the same time, the pictures of the board clearly show that there are no such connectors installed on the board.
For connecting your spdif connection to the DAC you can follow the diagram drawn out by Soren (link on first post).. use SPDIF1
Based on the info provided by Soekris, SPDIF input should be like this?
(Edited, added trafo and resistor)
Yes of course! I knew that I have to make myself the connection.I don't believe the board was ever positioned as such. At the same time, the pictures of the board clearly show that there are no such connectors installed on the board.
Thanks, but I was afraid of this:Based on the info provided by Soekris, SPDIF input should be like this:
No - according to instructions earlier you should put cap and pulse-transformer in between the input and the board - to keep the isolation!.
That must be balanced s/pdif input. I suggest you to use s/pdif2
Tibi
Tibi
Spdif2 is for optical (Torx) reciever output directly only as far as i have understand it at least.
Tibi
Soren's post to help with connections
- Digital Line Level
- Soekris' DAC implementations
