Hi Tony
I have often though about DIYing a heatsink such as the one you have described as the selection we have in our country is absolutly pitifull. However I am a little unsure of the effeciency of heat transfer through the joins of one of the sinks.
Have you ever done one before. Did it work well? What mechanism are you going to use to attach the Alluminium strip to the plate? Silicon Paste & Bolts?
I assume by Ga16 Aluminium Plates Bent into L's you are meaning extruded L Profile aluminium strips with a thickness of 1.6mm.
Any Pics?
Any Pics?
Jens wrote: I have some nice 1uF 63V epcos caps if you need them.
Hi Jens, are these polypropylene?
I can only find polyesters with the right size(RM5,5)
Loek
Loek
it costs me three times that amount to get the boards to my place!
hi tony,
pretty expensive huh... but the way it looks is still
ok for that amount....
heatsinks are still my problem til this time...
I've tried to email DAU England flatback extrutruded heatsinks and they
are worth GBP 10.00 each for every ten pcs. to high for a diyer....
rgds,
hienrich
Hienrich,
how much does 550 pesos buy in the Phillipines ?
Or, how much are 11 dollars worth overthere ?
hi jacco:
a dollar $ = more or less P 55.00 (Philippine pesos),
sometimes making us difficult to acquire components for our projects,
and one more thing, we suffer a lot of fakes here, envoking us to
save and buy the needed components abroad.....
inspite of these physcal crisis, we enjoy diy-ing.
rgds,
hienrich
rgds,
hienrich
hienrich said:
hi tony,
rgds,
hienrich
conrad engineering in australia is closer to manila and prices are the best anywhere imho....
i would love to order my heatsinks from them except that i will have to put out cash in one go...diy allows me to spend when i have the money and at my own pace.
anyway, there are metal shops in manila that retails aluminum plates, yes, you can order them cut to size!
i have done my chasiss all aluminum that way!
rest of the pics are here:http://gallery44059.fotopic.net/
PCB
Hello Everybody,
i'm very interesting by this project, mabe it's a little late but is it possible to find two PCB for this amplifier ?
If no, where could i find the PCB schematic ?
Thank's a lot.
Hello Everybody,
Thank's a lot.
OK Guys,
I've pretty much finished my KSA 50 so I am ready to start ordering the parts for this project. Has anyone worked out the values for the "to be determined" resistors on the BOM? I don't have a clue how to go about calculating them.
If it's any help, I am planning on using 64V rails.
Thanks, Terry
Thanks, Terry
Just wandering if someone can help me with a slight problem with the leach amps. I bought some boards from the gb and was wandering if anuone knows how to make them more sensitive on the input side of things? I have the original leach/super leach amps at the moment, but the problem i am having is that i need 2.5v rms input to give me max output at 8 ohms before clipping occurs and my cd player(2 of them) are only putting out approx 1.6v rms of clean signal. I can turn the volume to max but the output is not enough. Maybe i should add a line driver?? Dont really want to add anything else in the signal path though. Please help if you can.
Bowdown
Bowdown
Resistor hunt
Hi guys,
I have a pretty reality question to ask you, does someone have a
good spot to find the 1% 0.5W resistors? The resistors are close
to each other on the board, so sticking with the dimensions in the BOM is
a must. Only found distributors selling reel, well you know, 3000 units is a bit
more than what I need :-D.
Any help is welcome.
Jean
Hi guys,
Jean
Board is laid out using standard resistors. These should be available anywhere (I use www.el-supply.dk 😉)
\Jens
\Jens
bowdown said:how to make them more sensitive on the input side of things?
Make things even more difficult: change the feedback ratio.
source for 1% resistors
A very good source for those resistors is
http://www.mouser.com
They sell any values of Xicon 1% resistors in all values in multiples
of 10. Excellent resistors,1/4 and 1/2 watt, reasonable prices.
tony: very nice work😉
actually I've done PCB designs my self
but with the conventional cheap way. thank God t'was successful.
I've even tried tweaking with this amp utilizing all NPN outputs, using
+/- 70vdc rails, 8 pcs. of MJL21196 per channel, still with good sonic
results.
BTW what ouput devices are you using with yours?
rgds,
hienrich
results.
rgds,
hienrich
- Smaller Leach Amp V1
