Slewmaster - CFA vs. VFA "Rumble"
Slones rule of thumb for supplies is you need 10000uF of capacitance per rail for every 100 watts of output, That would be around 60000uf total per channel. In actual use you don't need near that either, but if you are going small on the transformer, go larger on the capacitance to keep bass response.
These amps have excellent PSRR so you don't need anything fancy for a supply. Some use CRC filters, but they aren't really needed. Ostripper designed a supply to go along with these amps. It's pretty simple. Basically 4 diodes and 4 big caps with a couple bleeder resistors.
I have a question about driving Magnepan 3.7 speakers with the kypton v2. So what are the things to be considered before building the amp.
Im using about 3 of ALF16N20W and 3 ALF16P20W with bias of about 350ma for each mosfet at 45V.
The load impedance is about 4ohm per speaker.
psu capacitors about 30000uf Mundorf Mlytic AG per rail.
anything to be considered before I connect the amp to the speakers? especially magnepan.
Going to balanced (or bridged) invokes increased power loss, not "no power loss".
Why do you said this ? The efficiency remain the same, and, if each side of the bridged amp is able to face to the current needed (each amp now have to face half of the impedance load) the power is increased by a factor of 4 (V²/R, double voltage) . The only trade-of a bridged amp concerns the damping factor.
One could bias the two amplifiers to exactly the same as the one unbridged amplifier. The losses in each bridged will be higher than the losses in the unbridged.
Now add the two bridged losses together and compare to the unbridged.
If you don't believe me, then use National's design spreadsheet for their chipamps, to investigate the losses.
It allows for bridging and it does not allow you to change the output bias of either chipamp.
balanced/bridged requires each half to drive HALF the load impedance.
Using lower rail voltages to drive half the impedance, so that the total output remains the same as the unbridged, will dissipate more power inside the amplifier.
True. But sending the same power in both situations with musical signals at normal listening levels will not make a major difference in temperature. Currents in the speakers remain the same. And bridge brings an obvious advantage with (pseudo) symetrical amps : Both rails are symetricaly sucked on each half of signal periods, and you double the reservoirs capacitances during those transients.
I will admit to being stuck in a Class A mindset when I think of power amps. For me bridging is always an opportunity to get voltage in the cheap and as a trade off, increase bias. I will be trying the krypton ND as well as Vzaichenko's TubSumo.
Also, look at this one - VERTICAL front-end:
http://www.diyaudio.com/forums/soli...e-old-ideas-1970s-ips-ops-41.html#post4578177
Came out nicely, as well as the non-switching OPS 😉
More info on different options - see the link in my signature.
Valery
P.S. Sorry for a little bit of advertising in my brother Ostripper's thread - just coincidence 😛
