Slewmaster - CFA vs. VFA "Rumble"
Because my previous simulation have lower THD.
Normally, it's easier to achieve lower THD with higher rails 😉
So, I'm sure, if you set the key regimes the same as with the lower rails - you will get even better results.
By the way - what OPS do you use for simulation together with VERTICAL?
NFB is rather low-impedance, so the front-end does not work properly without a power buffer...
I use 3EF OPS. I will optimize it later 😉
This IPS is very good. Must try...
After all the work he does, almost without being asked, I wouldn't be surprised if he just gets sick of looking at the forum and familiar designs so much. I know I do. If he can stand being off the forum for such a long time then I think he must need time to recharge his batteries. I wish him all the best.
I had a mailing address for Pete that I used to send him some things but that was before he moved when he couldn't get any more internet service. I don't know if I sent a letter to him if he would get it, perhaps there is a forwarding address at the old mailing address. I could give that a try. I was counting on him to do the surface mount design we had talked about, I just hope he didn't walk away from everything but I doubt that is what is happening.
Pete "Olly olly oxen free" !!
had to look it up. it has been a while since i had to use it 🙂 but for the non hide n seek children in our audience, this is what it means
a catchphrase used in such children's games as hide and seek, capture the flag or kick the can to indicate that players who are hiding can come out into the open without losing the game
