SissySIT
yes, its already mounted and me almost concious : ) (but i´m just afraid to make it with 50k volume pot, there is too small region to trim), i´ll try to get a multiturn 10k today.
another one, when i took off the F6 PCB from heatsink, having been insulated with keraterm, i saw little holes in the pad, obviously not so good idea to use them twice!
Official Court Jester
Joined 2003
I believe you'll find Keratherm in 10x10cm format at Conrad.de
though , that damn thingie is so massive , for 50W of heat , evem 0.1mm thick mica is overkill , with goo of course
I'm regularly using punch method for opening holes in mica , in this case nice** M5 bolt (as punch) and M5 nut (as female ) will do the job , if you find mica sheets
**means proper clean forehead of bolt
edit: just imagine I break this post in 4 separate ones , and everything is easier to grasp
:clown:
