Single sheet TH challenge
which do i order
Pink or Purple
34Hz THorn v3
View attachment 1337548 View attachment 1337549
In the Cad model above, If sides aren't fitted over the flare, then it models as a TL with 1/3 offset and smaller bandwidth but lower tune. Anywhere from 20-40Hz can be tuned, changing segments in the template. Even 160 Sd seems best for this low Vas driver, no taper. I will be building that to break it in and then take T/S. But off-topic as doesn't use the TH function
View attachment 1337572 View attachment 1337574
Anyway, that's enough about these. Don't think they qualify. The PRV driver sim looks good
This is such an overdamped simulation that reality will sound very disappointing and begs for a bigger TL/etc ??
Hey all.
I am planning on building two of the SS15 shortly, I have a lot of ply offcuts at work and was wondering if it's worth making a 3 or 4 sided horn extension that could be clipped on the exit and extend the horn length...
Perhaps the extension panels could be u clipped from each other and packed flat, or even hinged...
any thoughts welcome.
Cheers
Phil B thought it was worth doing:
He also posted more pictures in post 178 and 180 in that thread.
I knocked up a 3d Model of SS15 from the metric plans.
Included the original in dxf format + a revised dxf with a few cleaned up cuts and overhangs.
Most cnc's can import dxf files if anybody needs to use them, but double check the woofer cut out size and everything else just in case.
Final angle cuts will be done on a panel saw..
Also included a Fusion 360 model.
Change the file extensions' from .txt to .dxf and .f3z to view/use
Cheers
  • Thank You
Reactions: rrobot and maxolini
