Hi tb46,This was stuff I have worked on now and then;
Oliver, thanks for explaining 🙂
I guess MS knows too well that there are still millions out there in labs/research/government programs running 'old' OS and not contributing to their survival and s-holders.
Regards,
Djim
Yep, built a pair using those discounted 4ohm LAB15-alikes. They measure almost exactly -3db at 35hz. One PEQ takes care of the peak at the top of the band no problem. Love the sound, and the output is frankly fantastic.Ref.: Post #1499
So I find it to be very valuable information, that there is such a big practical/subjective difference between the extended SS15 and "subs that reach comfortably down to 35hz" (about -3dB @ 35Hz ? / are you talking about the Keystones?).
Regards,
Went with a 23" aperture. What's also nice is that the 15" driver will fit through the aperture, so need for a removable front.
Here's a pic of 2 of the SS15 V2 cabinets. Currently I've got another of the 2 LAB15s, and I'm hoping to come up with a design that uses 2 drivers, double the power, half the size, nearly same output as the Keystone. Something a bit more portable but still very loud. It's a shame the Keystone isn't laid out in an isobaric-mounting-friendly design, or it would be as easy as halving the width. The sim for that looks pretty good.
Hi zettairyouiki,
That looks quite nice, flat to 35Hz, but that's a pretty big hump 80-120Hz.
So now you are looking to pack 2ea. LAB15 into one box, make the box half the size, and get to about the same output using twice the power? Have you tried messing w/ djk's PPSL in a bass-reflex? But then, that wouldn't be a tapped horn.
Regards,
Regards,
ive got 6 SS15 of which seem to all be constructed slightly differently, and all have their own unique tone. all run a FS audio JB1500N from VFM audio in australia.
i use them outside in the group of three pairs, center pair, and a stacked pair on each side.
and my small combo
they blow me away every time i use them, which is about 2 or 3 times a year in anger, despite knowing what to expect.
is there anyone who can do up a 3d model of an SS15 for me so i can 3d print a set i can use on my desktop with 35mm drivers?
and my small combo
Clever !..................is there anyone who can do up a 3d model of an SS15 for me so i can 3d print a set i can use on my desktop with 35mm drivers?
Add in some inter panel bracing to allow thin plastic panels to save plastic and weight and time and maybe save cost.
I'm not too fussed on saving plastic or weight because they're only going to be rather small, I'm picturing the model with one side panel off so the internal walls get printed standing up on the other side panel. So no internal bracing will specifically be needed as long as the internal panels are thick enough.
I don't know enough about the modelling process to do it myself or I would
I think time and plastic are a big cost to 3D printing.
Thin panels may make a big difference to who ever makes this for you.
How about asking to move these posts to a new Thread?
I have asked this question in two threads. One about the ss15, ie this one. And another 3D print specific thread.
Yes they're too small, thin, weak etc but it's my first successful model and then also print of anything. So I'm pleased and now have a quad of mini scale SS15 subs to display
They actually sound exactly as you would expect them to having such a short horn path. But they sound decent considering ha
What frequency does the little 35mm driver get down to?
Does it need a mid, or treble, to augment it, or can it operate as nearly full range?
It's a full range but it's a pretty heavy little woofer. Can physically reproduce low frequency right down to bout 40Hz but getting the right cab will prove tricky as no t/s specs.
Back on topic tho, the 3D model of the ss15 is rather cute.
Oh bugger, the mid and treble has to come out from the back of the driver.
I thought the little 35mm driver was intended to fit inside the S1, S2 space but front mounted on that panel.
When I've got some more print filament I'll scale it up to suit a 4" Driver. I've got a pair I could use for this. I'll report back once I've accomplished this
THAT's WHAT I'VE BEEN LOOKING FOR!!!!!!!! ,
A portable PA, 135 dB @35 Hz, BENG. Fits in my pocket.
Who's building a digital amp of 2 x 2 x 0,5 inch 3 kW?
Hats off sir.
Hats off sir.
- Subwoofers
- Single sheet TH challenge
