Powered up the one channel of the SECFA amplifier without drama or black smoke, Haha! Very smooth 😀
Borko’s Recomendation to center VR6 before installing it was perfect, the 'O' node was only 1.5v off from half the psu voltage.
I’m set up to use just VR20 for bias adjustment, no additional switches or resistors. For initial bias current VR20 trimpot was adjusted to 50k, after the amp settled down and heated up, it’s currently adjusted to 63K and thats good for 1.3A with a 39.5vdc psu. The psu consists of an Antek AN6432 trafo and a single rail SLB psu with the PNP attached to the heatsink via flying leads.
The DC offset is virtually 0, hovering between -1mV to 2mV.
So far so good!! Next phase will be MUSIC!!!!
Vunce, could you please measure few DC voltages, Vgs of J112 (Q2) and voltage over R7? for comparing...
You are flying Vunce - very well done. Now the proof will be in the music, enjoy the listening. Looking forward to your thoughts comparing it with other amps built by you over the last few months.
Thanks Gary 😉
Got first sound tonight! Music sounds good, very quiet background, I couldn’t hear any noise, hum or hiss at idle. As usual the real listening can’t happen until the second channel is born and moved to the big system. But all signs are good and it passed the ‘quiet’ test. Heatsink temperature is 47°C, directly on the mosfet/BJT devices is 50°C @1.4A bias
Hi Borko,
I attached a marked up schematic with the vital health statistics of the SECFA. How does she look Doc? 😀
Note: R9 is 22R
Hi Borko,
Note: R9 is 22R
Thanks Gary 😉
Hi Borko,
Note: R9 is 22R
😀 everything is ok, the only difference is that I get little higher (2.7-2.8V) Vgs but that`s due to J112 jfets...
T1 has 0.3W dissipation at idle and 0.6W at max output swing, maybe it`s better, just in case, to attach smallest heatsink you have, little metal plate or something like that... But I didn`t had a problem during the measurements at full swing..
Any data about max dissipation for TO126 without heatsink?
Maybe, for the numerous noobs reading this thread and interested in trying this amplifier, it would be good to add some more info about the power-supply.
For exemple, basic info like power/voltage of the transformer (and fuse value) to reach the (recommended?) +45V at the outputs of the power-supply at both R and L outputs 😱
Ok, no problem, I`ll include that in the article update...
The topology is very flexible. I'm experimenting with scaled down version of the same circuit for a preamp / headamp on a proto board.
It's DC coupled and it doesn't need a servo! 😀
I’ve had the mono channel SECFA amplifier playing all day and there has been quite a jump in sound quality compared to first listen last night. The output capacitors are going to make a very big impact to the sound of this amp. Don’t use “buy by the bag” caps for this project 😀
Hi Vunce, thanks for the encouraging update on the sound. I was thinking of using parallel Elna Silmic ii or Nichicon UKA caps on the Cap board for the 10,000uF output cap.
The Elna's go up to 1,000uF 50V and the Nichicon's go up to 3,300uF 50V.
Thanks for the tip on this.
Good options Gary! 😉
Correct me if I’m wrong Borko, but the output capacitor doesn’t see more voltage than half of the power supply. So, even with a 45vdc psu that’s only 22.5v, a 35V capacitor there will work and open up more options for ‘fancier’ caps.
Vunce I think it`s a matter of new caps, they need some time, yes you could use 35V cap.
BTW, try R15 bypassed with JP1, I prefer that option sounds better to me.
- Single Ended CFA
