Since my thread went to Texas.........
As Straight As An Arrow....
I'm not sure if p2p has that much of advantage comparing to well designed board. It's certainly safer for some people to do p2p than work with badly designed pcb.
This was about the gainclone, right?
BTW, how badly designed does a PCB have to be for it to become unsafe?
That's one reason I'm not using that often PCBs these days. I much prefer p2p, 3D layout, because although it does not look that good, it sounds better.
What do you find wrong with those two comments? They certainly don't exclude each other.
Maybe not mutually exclusive but a little confusing for those wanting to know where it is you stand on this...
Whether you like it or not you now are a GURU and are expected to act like one: confident and opinionated are good places to start.
So, wouldn't it have been easier to just say:
O.K., if it were me I'd rather use P2P for best sound but it's just too time consuming and not ideal for repeatability so we chose to go for PCB in production units?
From a production/economical POV there are at least half a dozen other reasons why not to go for P2P but I suppose you caught my drift by now.
Cheers,😉
Re: As Straight As An Arrow....
Actually, we go p2p in production units.
You also said somwhere else:
fdegrove said:
They may not be useful to or even understood by everyone but they're always informative in some way or another.
Thing is, if you understand what he's on about you probably don't need to be told what to do anyway....😀
Why couldn't I be using a similar approch? Although I'm not an expert in electronics, I'm pretty good at other things (needed to put a piece of stereo unit together).
Peter,
Maybe you thought I was addressing you but I was speaking in general.
Certainly.
Nothing wrong with that at all, it's just that we can't possibly excell at everything so we best stick with what we do best.
At least, that's what I'd do.... even though it can be tempting sometimes.
Cheers,😉
One Week Of Sinbin...All Inclusive.
What is the difference between a cactus and a group of moderators.............
Last shot:
On a cactus, all the *****s are on the outside.
Next riddle:
Why does the River Mersey run through Liverpool?
Cheers, 😉
Edit: workaround the asterisks: PR*CKS. *=I
Till's moderator nightmare continues.
