Simplistic NJFET RIAA
Finaly my setup has ended. One channel ok, the other dead!!! Both +34v, 4v ok, but the left without sound...
Compare DC voltages between good and bad channel first. So to narrow down the problem part/area. Fets drain to ground figures for instance. If nothing's wrong with those, compare signal path continuity.
Finally got my FSP cased up. I haven't mounted the transformer or raw PSU board yet as I wanted to listen for noise. None detected at tweeters full volume. This sounds very good! I may do a UFSP in the future.
I may put a vandal switch for power on the front (where the LED is now), and will want to make sure the voltage select/momentary switch board for that doesn't introduce any noise before I finally mount things. I also will need to dress the wires, etc. I have one of Antek's steel transformer covers to use on this, and may also put a mild steel divider down the middle for noise, just in case I go for MC cart with more gain in the future. This one is set at 42dB IIRC.
