Simplistic NJFET RIAA
BTW, many semiconductor manufacturing tools are use electrostatic chucks to hold Si wafers (today, it is mostly 300mm in dia) in vacuum chambers. It is impossible to remove wafer from chuck without braking it when power is applied. It is hard to imagine how strong these forces are.
ART-9 is so good I really don't know how far behind it may be left or not if mounted on that same system. Surely the Zep played without any congestion, smooth not HF noisy, and full. Like in a live jam session not through strained Hi-Fi. There was an ambient aura enveloping the band as they were competing each other. Telling you they were together. Due to very smooth natural midrange. Else the Zep can turn ears to biscuits when replayed that loud. In Bonham parts the heft of the drums was there with bass body and mids thwack sync. Not detached.
"Page said that the album took only about 36 hours of studio time (over a span of a few weeks) to create (including mixing), adding that he knew this because of the amount charged on the studio bill. One of the primary reasons for the short recording time was that the material selected for the album had been well-rehearsed and pre-arranged by the band on the Scandinavian tour."
Source Wikipedia
So, I must buy it. During my time in USSR, such records were “the Forbidden fruit” and just tiring to acquire it from black market was quite dangerous. We could end up in jail. It was considered by law as inclination and propaganda of the west. 🙂. What a time?, Ha...
🙂 I like Sochi and I been there many times. Close to Greece by weather and nature look. Black Sea is amassing there.
BTW, He has more money than Idaho, as State, spends over 5 years for all Sate related expenses.
I’ll send him an email with proposal... 🙂
Hi all, I'm so excited I got to share a pic with you!
I just finished one channel of the UFSP and connected it, playing a very nice LP right now!
Currently right channel only, the left is still going through my Bugle 2 that this is going to replace.
I'm running at high gain from a Lyra Helikon SL (.22 mV). First impression is really good (but details later, it's hard to tell from my mixed debugging setup).
Noise seems minimal, certainly much better than the Bugle2, even without the proper grounding and shielding in place.
Thank you Salas and thank you Teabag for this wonderful design and carefully put together kit!
Hey, nice progress, now to the next channel. Try keep the shunt regs as close as practical to the main units in the final configuration. They won't need such a hefty sink, just the big chassis floor will do. What are those C3 C4 white film caps? CDE?
One channel up and running here as well.
Set the bias on the UBiB to 34v before connecting the main board, set the input load at 47K, and gain for 43db.
TP was 4.92v at start, dialed the UBiB down to 32.3v and the bias is steady at 4.00v with minor adjustments to the main board pot.
On this board, I measured IDSS of Q4 @ 9.39, Q5 @ 9.47, and Q6 @ 10.27 prior to install. Set R8 @ 54R and R11 @ 1.3K. Voltage across R10 is 23.4v and voltage across R11 is 11.68v. Should I increase the value of R11 to get closer to 14v?
C3 is a .1uF FT-3 and C4 is a Solen (both of which I had on hand). Once everything is boxed up and running, I’ll start rolling some caps. Thinking a Miflex KPCU for C3. I haven’t used the CMR before, so I’m leaning toward getting a pair for this build. I have some Mundorf Supreme 2.2uf in my Valve Itch so I’ll probably give those a roll too if all goes well.
I had really hoped to put the amp in a 1U chassis, but it’s gonna be real tight. I purchased the shortest electrolytic caps I could, but it’s going to be challenging keeping under 40mm high I think with C3/C4 on board.
I can't make the numbers work for a 1U chassis with the sweet caps Tea included in the kits (all tall caps slightly over 40mm). Plus I have some fancy-ish Clarity caps that will break the height. Non-ultra version is totally 1U-able with shorter heatsinks. So it's a 2U or custom (or sourcing all new sub-30mm caps and same height restriction for C3, C4). (my personal build will be custom around 50mm-60mm height all in).
Question: Are the LED array values for Ultra the same as previous version? I don't see it noted anywhere that the voltage references are different. Tea included a bunch of red LEDs.
