Nice hifi 2000 enclosure, Salas. Galaxi Maggiorato 33 x 23 x 8 cm I guess
Solid Alu top and bottom cover?
I wonder the two XLRs.....
Yes I confused with load resistor, Villa cost a bargain only 40.000.000€ instead 95.000.000 CR9.....start to imagine playing togheter Messi, Iniesta, Villa will be unforgetable like Nat King Cole!!!!!Can't be 150, merlin.... Those are yhe millions paid by Barca to get Villa ! 😉
40 millions before the South Africa, now Valencia will ask the difference! 😉
Thanks God you don't have Xavi too..... Yesterday was superb!
If Mike can do the last favour to Salas can change the Alu cover for "corian"😉
We have Xavi 😀 Xabi Alonso is from R.Madrid😡, now we try to get Cesc Fabregas, remember we have also a 1st class midfield Busquets😀
Merlin:
Single 1.2 makes it 90% near to two and since I use humble parts from my hobby stash in this 4 JFET, doubled up cascode test build with B1 tail and 22k RIAA, I am not nervous about perfection. Probably many things to tune before parts. Filter capacitors are 10mF-10R-10mF 63V Samwa CRC, nothing special at all, the RIAA caps are NP0 ceramics, the coupling caps are CCCP and no name China, cabling will be no name Italian RG-179 impersonator, the resistors are metal film from deep inland China probably. 😀
Massimo:
Yes, Italian enclosure, sides, front and back Alu, top & bottom ferromagnetic.
Will wire two pseudo balanced XLR parallel outputs to have easy interface to balanced gear without resorting to adapters.
Massimo:
Merlin:
Single 1.2 makes it 90% near to two and since I use humble parts from my hobby stash in this 4 JFET, doubled up cascode test build with B1 tail and 22k RIAA, I am not nervous about perfection. Probably many things to tune before parts. Filter capacitors are 10mF-10R-10mF Samwa CRC, nothing special at all, the RIAA caps are NP0 ceramics, the coupling caps are CCCP and no name China, cabling will be no name Italian RG-179 impersonator, the resistors are metal film from deep inland China probably. 😀
Massimo:
OK now I understand it's a prototype, sorry seems too perfect to be a proto!!!😉
Only one TX?
How can do two pseudo balanced XLR parallel outputs?
But corian isn't shielding the circuit.... Copper can be a very good material thanks to its electrical and mechanical proprieties. In that enclosure it can be used up to 4 mm thick, about 2.5-3 kgs each sheet.... expensive (nearly 10€/kg the raw material) !
But if Salas wants, I can have the sheet cut to measure easily 😉
Thanks Massimo for your kind offer. This a test build. I will let you know when I will be making the final ''Midas'' version.🙂
Merlin:
Massimo:
Yes, Italian enclosure, front and back Alu, top & bottom ferromagnetic.
Corian + shelf adhesive Mu-metal will be mine 1st choice less expensive & IMHO more effective.😀
In Spain "Midas" is like say "gold" perfect name for your final version🙂
RIAA resistors
R4 6K81
R3 45K804
R5 1Meg
Run the sim, you can use 15n, but fit 1Meg parallel to 6K81 too.
@Massimo
Everytime Spain team played after I got an e-mail from Erno Borbely is the 1st Spanish supporter team, not only now World games also in European Cup.
Sorry for off-topic Salas.
run the sim, you can use 15n, but fit 1meg parallel to 6k81 too.
Χάρη
Big plans for meta crisis lavish version.😀
Χάρη
mmm... better ευχαριστώ (πολύ)
Do you prefer Spain vs. Germany or Argentina 😉 (Messi shooting at Casillas, but all 'n all he's from Real....)
Signal to pin 2, GND to pin1 & 3.
I am pro Latin both sides of the pond. Both in music and football. In a soul league of their own.
- Analogue Source
- Simplistic NJFET RIAA
