Simplistic mosFET HV Shunt Regs
No I didn't measured the parts burned, Q1 DN2450 was destroyed.
I discovered D3 in the schematic & D1 in the GB pcb was burned, I desoldered one leg & now can reach 60mA of current but Vout fixted 26V, I follow looking for where is the issue so I will measure, irf840, 117 & 1381.
Out of curiosity, and to make sure that there is no problem with the board or the GB kits, I quickly solder and tested one more SSHV2. It took an hour to build and test it.
As you can see all went fine and there is absolutely no problem.
Felipe, I think that you are doing something wrong on your build, maybe some photos would help.
George I don't have words to describe the very big upgrade using the SSHV2, I never suspected that tubes can reach same or very near level of information like SS, now I understood (thanks to Salas) how much important is to have a very good shunt regulator, also thank crt to his layout & to Tea-Bag for the GB and all people like you & others testing the beta boards to be possible all of us enjoy your splendid work, thanks to everybody involved.
Good report, ending well = all well. I don't think that any hum has to do with line ripple especially when with regulated B+. First of all 100Hz ripple would sound more like a 'bzzz', its harmonic noise with many midrange peaks, 50Hz sounds deeper like ''hUmmm''. Can be some small ground loop or field. Possibly. Even instability, but that normally sounds bad too and heats up much.
I increased 220uF the PSU but isn't fixed.
I grounded the MM RIAA chasis because Speakon is only 4 pole (2 for heaters + 2 B+) so I wired one cable between GND chassis PSU to GND chasis MM RIAA & the hum isn't fixed, I have the same level/amount of hum but the tone changed seems more low after seemed more high.
