merlin, re do the solder joint on rca ,don't look so good, at last on pic.... ag without pb ?
thanks/grazie nico🙂
Salas/others,
Due to space limitations I will have to design my own board for 2 SSHV2's.
- Are there any layout recommendations? (components that should be as close as possible to one another, components that should be furthest apart?)
Thanks!
Thanks!
The input CCS is critical for compactness primarily. In the GB PCB it works with 100 Ohm gate resistors which is generally not that common, people use >=1K to damp the depletion semis, alas if you need to, it cuts PSRR dB max spec in the highs.
S+ F+ S0 F0
Forgive my lack of knowledge but that four wires out looks complicated to me. Usually I just have to deal with "in, out and adjust"...
I want to use the SSHV2 with my 12B4 preamp (Salas version).
A bit more information would be welcome.
Thanks.
Thanks.
You have two pairs of wires that connect at the load.. Sense and Force (remote sensing).
So both S and F are going to your plus side while both SO and FO go to the ground side. You should also download the build guide at post no. 2704.
Connect each S to the respective F at the regulator.
Now you have a two wire connection to your load.
It's that easy if you want it to be that easy.
I have. Those Sense and Force connections are needed to get the regulator performing well. Thanks.
No. they are used to minimise the effect of long resistive/reactive connections between the sensing circuit and the load. If the load is located at the Shunt mosFET and the sense traces were tapped into the same points then separate S & F would not be required. But, we can't build a practical load circuit where the load is at the FET leadouts.Those Sense and Force connections are needed to get the regulator performing well.
Similarly if the load is directly connected across the reg output terminals, then the S would be connected to the F at the output terminals, as I suggested above for "easy" implementation.
Thanks.
The subjective upgrade will not reach 100% potential if you will skip the 4 wire connection. The longer the cables the more the benefit to have by changing your now traditional power feed double wire run in an already made build. It will work in the classical way if the force and sense are closed right at the reg's output connections if rewiring is a hassle no problem, but do try to upgrade later. Recommended for SSHV2.
Caution: Don't operate the reg without sense and force closing circuit either remotely or locally. It may bring damage to the reg.
Got the picture in the meantime. It looks like a commercial power supply I saw with some kind of "probe system" inside. It was connected to a pair of twisted cables. But the current was much higher and the voltage much lower. The situation is different here. High voltage with low current seems less critical.
SSHV1 for 60 Volts / 50mA output
Dear Salas, All,
I built SSHV1 for 300v, I would kindly like to know if the same circuit may be adapted for 55-60 vout and 80-90vin with 50-60mA load and which value I may use.
I searched the threads (not all) 🙁 but I didn't find it.
I found one in the SSLV1.1 but I would like to implement it with the SSHV1 circuit.
Which value should I modify on the SSHV1 official schematic that can be find here:
http://www.diyaudio.com/forums/powe...stic-mosfet-hv-shunt-regs-97.html#post2084348
Thanks a lot in advance for your help!
Gianmaria
Dear Salas, All,
Gianmaria
@ 60mA & 35Vdrop, the CCS FET will need to dissipate 2W. It needs a sink.
If the output is shorted, the dissipation jumps to 5.4W. Will the FET survive a shorted output? and return to normal working when the accidental short is removed?
One of the really nice features of a CCS Shunt regulator is that it can be bomb proof. But high input voltage makes this more difficult to design for, not impossible.
Could someone please explain the point of R6 1R8, and how critical it is to get the correct value?
Cheers
Cheers
Stixx is correct.
Also if there isn't any special Wattage need for R6, you can use 1/4W. C3 is a dead end for DC, so virtually no energy consumption on R6.
Together they form a Zobel terminal block that helps transient overshoot performance. See how it overshoots at IRF840's gate for current without the Zobel.
OK, so that is the reason for it. How about value? The smallest I have is 1R or 2R.
- Power Supplies
- Simplistic mosFET HV Shunt Regs
