Simplistic mosFET HV Shunt Regs
If you change it, measure idss to see if dead or not.
According to datasheet, vgs should be -.2 to -1.5V.
You can adjust current, so front stage is OK, and we have checked that 840 and ksa1381 are not damaged, there is nothing else to go wrong. If you replace the 117, check d3 too. It could have gone south too.
Zener distroyed?
Take it out temporary.
I taked it out but still 15-17Vout
OK I used the 117 supplied with the mini-kits without measuring the Idss now I will use one near 4mA of Idss also I will check D3. I disconnect D3 schematic that is D1 in the GB pcb that I have but still 15-17Vout.
