simple preamp from half 12ax7
I'm not sure that I believe the model's bias conditions for a 12AX7, but that can be adjusted later if necessary. And, are you committed to a B+ of 300 volts? Could you get more? Linearity gets better with higher B+, and it's cheap and easy performance improvement, if possible.
Big FETs mean big capacitances, which means big signal currents to drive them, which means big idling current through the follower. Paralleled sections of type 6SN7 (and its family) or type 5687 would allow 15-20mA, which is a good start. Triode connected type EL84 would allow 30-40mA and makes an excellent follower. Other button based output valves are cheaper and available in lifetime quantities, especially the Russian ones. (Don't wait, though.)
*All* cathode followers need a cathode stop, sometimes called a build-out resistor. This should be connected directly to the cathode's socket pin, like a grid stop. Do not skip this step. Maybe start with 100R.
YOS,
Chris
i have only 295v i cant get more.
think i start from 12BH7
thanks Chris
FET capacitance is a non-issue when it is used in the way we are talking about; you will find only positive comments about this approach and especially it being very much superior to any tube alternatives. After many years of reading about this I’ve never found an objection that has survived, except for the perfectly acceptable ‘excuse’ of “but I just want to use a tube because that’s what I want”.
From your collection, I would choose the tube with highest transconductance for the follower. This means do not use the ‘AX7. The ‘AU7’ would be much better.
I tend to agree with you, regarding the transistor follower, it just seems like another power supply is needed.
do you have simple schema for that?
thanks
Does the following circuit meet the requirements of 20ma?
the IRF820 as follower can do this job?
My take on it since you have 12AX7 and 12AU7 already.
Great, thank you very much:cheers:
The 12AX7 stage can (and therefore should) have a much higher plate load resistor, maybe 300K Ohms, for best linearity and output swing. Easily done since direct coupled to a hi-Z gate; limited only by need to drive some parasitic capacitance.
MOSFETs make a convenient follower, and have higher transconductance than any practical vacuum valve, but a couple of caveats:
First, as folks have already said, their gate junction is fragile (super-duper thin insulating layer), and must be protected from over-voltage, even in handling! Wrap a bare wire around all three leads and solder a 12 Volt Zener from gate to source, right on the pins. This will allow you to handle it without special work mats and other voodoo.
Second, it'll need some serious heat sinking to dissipate enough power to be useful. 300 Volt B+ supply, half of it across the MOSFET, times 20mA (an absolute minimum IMO) is 3 Watts. 50mA will be 7.5 Watts.
3) All "cathode" followers need a stop resistor, mounted as close to the device as possible. They're a high feedback stage with an inductive output characteristic, so love to oscillate with a high enough Q capacitive load. The stop resistor damps this Q. Folks always tend to skip this important part, and then complain that cathode followers "sound bad". Either their scopes can't show the bursts of parasitic oscillation, or they haven't looked. Nuf said.
Without defining the load you need to drive, you can't know how much idling current you'll need. So that's the first step. If you research the topic of "slew rate" you'll get an idea of the interrelation of available driving current and load capacitance, and you can decide how much overhead, or margin, you're comfortable with. I'd guess that you're not planning to run loop feedback from the output of the final VFET, so you can cut this margin way down safely.
YOS,
Chris
What is Gain Structure?
Excellent
FET followers are, of course, a popular option and they run off the same power supply as the tubes. Here’s a good thread that discuss the merits of particular FET choices. And you can add a zener diode to protect the FET.
thanks
guess right. 100ohm grid stopper is a must.
i order IRF820, I will build the circle and publish results.
Thank you all
Excellent
thanks
Thank you all
sounds good, don’t forget to heatsink that FET of course, and slap an output cap with 100k+ to ground after the cap to keep high voltage dc confined to the preamp.
I wasn't clear enough about the source stop resistor. This is *another* stop resistor, in addition to the gate stop. It's mounted, just like the gate stop, right up close and personal to the MOSFET itself, in the signal output lead. 100R would be a good starting point.
Your circuit shows about 1.5mA idling current - are you sure that's enough?
All good fortune,
Chris
