Simple LED display for DAC freq?
Hello!
I Need It for my Dac project.
So ...Is there a Simply electric diagram that use i2s signals to obtain with led indicator for
44,1khz
96 kHz
192 kHz
+ Lock indicator?
Antonio
I think Marcel's circuit above is the simplest possible one that doesn't use a PLL. However, since you say "Lock indicator", I guess you're looking for a PLL-based solution. If so, refer to 74HC4046 , 7046 , 9046 datasheets, preferably the older ones from Philips.
The same disclaimers as for post #6 apply. 74HC123's from Nexperia or TI, definitely not Toshiba.
Regarding 2), please change the 15 kohm resistor of the second monostable multivibrator into 8.2 kohm in series with a 10 kohm trimming potmeter, and the 6.8 kohm resistor of the third monostable multivibrator into 3.9 kohm in series with a 5 kohm trimming potmeter. Trimming potmeter with wiper and one fixed contact to the +5 V, resistor between the other fixed contact and the capacitor.
Reactions: tonimxp
