Are mains power cables available with direction arrows too?
Not usually, but I can build one for you. That would be 1000 quid, please.
Triax is standard for electrometers also and with one of the insulators made of special low mechanical noise material.
And usually sapphire connector dielectric (instead of the regular teflon).
No, it's probably a correct and money saving decision. Last time I've checked a Keithley picoammeter schematic, the protection was between the hot and the guard. Since the guard is driven to minimize the leakage, the diode sees essentially zero volts during normal operation. So the 1N914 leakage is also zero, a picoampere diode as BAV40 (5pA@5V) would not do any better. Actually I've never seen a diode with 1e-17 leakage (62 electrons per second), they may exist for some nuclear detector applications?
Hmm that seems a lot but you do come across as very expert so I'll take one for my cassette deck. I would like interchangeable plug and socket mind so I can show my latest wife how much better it sounds in the correct direction.Not usually, but I can build one for you. That would be 1000 quid, please.
BTW, several encoder vendors have specific shielding requirements for their long encoder runs. It is a double shield technique, coaxial shields.
But only one of them is connected to ground at both ends. One is connected only at the receiver. The inner shield does not connect at the encoder, the outer shield is connected at both.
The theory: The inner shield is an electrostatic shield. If this were the only shield, the different potential between grounds would show up as common mode noise in the differential pair signal.
The outer shield connects to ground at both ends. Any ground current will travel the shield, and the shield will try to limit the common mode voltage excursion. The beauty of this system is that there is no magnetic field within the outer shield as it is cylindrical. So it prevents any coupling to the inner signal wires, and further reduces the voltage potential end to end that the electrostatic shield protects against.
The down side to this is...I typically have 4 to 6 of them running 100 feet from rack to equipment. While each cable protects it's internal signals from shield currents, nothing can protect the other cables from the external field of the shield currents. So the design from the vendor falls apart once multiple devices are used.
jn
This seems to be an application of what you mention - a USB cable with 3 coax shields which can be connected in various ways
Lush^2 - Share your configuration experiences - General Forum - Computer Audiophile
Is this a suitable mitigation of Shield Current Induced Noise - What's your take on it?
Jim Brown's paper is an interesting read on this Shield Current Induced Noise - Causes and Solutions
BTW, do you have examples of this dual shielded coax?
BAV199 does femto amps
Are you sure, BAV199 data sheet tells a different story https://www.diodes.com/assets/Datasheets/ds30232.pdf
Can’t find any standard product under 3pA@5V, these can be close to some fA at a few mV.
Wrong vendor? https://assets.nexperia.com/documents/data-sheet/BAV199W.pdf
Besides that I've measured them, they perform similarly to the gate of a 2N4118a which is <20fA at Vgs ~ -1V. You can use the exact diode equation and an electrometer to compute Is then the slope at 0V is IIRC 2Vt/Is.
The paper is reasonable. One factor in cable design he missed is how cylindrical the braid is. The fillers are sometimes used (not sure if intentional or not) to make the braid fully cylindrical. If not done, the braid will couple to the wires.This seems to be an application of what you mention - a USB cable with 3 coax shields which can be connected in various ways
One place I would be concerned about is his test setup, he forms a loop by connecting the shield drive to scope channel B.
Other than those small points which probably have little impact on results and conclusions, a well done paper.
I don't have any of the cables, cables are turnkey for all the installs, the techs would cut the rack end to length, the cutoffs always end in scrap. We had lots of scrap as we'd pull ten or so like type cables through tray and conduits so didn't have the luxury of pull to length.
Since we have multiple cables in tray, the concept of triax is of no help to us due to one cable shield being next to another.
Jn
Yes, Max. vs. Typ. performance.
AFAIK Is is best TBD from extrapolating the forward log(Id) vs. Vd to zero Vd, then calculate the slope @ 0V.
I use an electrometer to measure log conformance to as low a Vd as possible. Also watch out for those glass diodes and photo current.
At least in the USA, mains cables have different connectors on each end, thus they are directional and you can not reverse them (without making adapters).
I used FJH1100 from Fairchild (now Onsemi) that have 3pA@5V Max. and they were under 20fA@1V but those are expensive, about 10 quid a pop.
BAV45 are also good, if you can sort them, but the good samples in metal can are today as rare as hen's teeth.
Ok, I'll do two for the price of one, each with a different cable orientation.
Cap burn in
Here is a link to a YouTube video showing how Audioquest burns in capacitors that are used in their power line conditioners. Someone had brought up that on the Audioquest web site they talk about using a method that is from NASA for burning in their caps. This shows how it is done.
Start at 6:15 into the video.
YouTube
Do you think that they would invest this kind of time and money if it did not make the caps sound better?
YouTube
So if you need a meter to measure femtoAmps:BAV199 does femto amps, but the leakage is not the full issue it's the resistance at 0V (~2Vt/Is), remember the leakage is meaningless if there is no potential to drive it. 1N914's are gross in this respect. BAV199's are pennies.
AMETRIX | USB Model 101 Picoammeter
Mostly Mexicans on minimum wageHere is a link to a YouTube
Here is a link to a YouTube video .... This shows how it is done.
YouTube
Boy! Such naivety!
Investment would be determined by whether there was profit in it!
I prefer this Keithley 610C Solid State Electrometer. This is one of those jobs where an analog meter helps.
- Member Areas
- The Lounge
- Silver RCA Cable-share your experience, opinions here!
