...by the way...the polarity of the tantalum caps are like positive in the above example on the left, so where the open end is, is negative, correct ?
Since Pavel is fully in DSC production now, I'll try to answer some questions. Of course, Pavel correct me if necessary. 🙂
There was a quite big discussion at Russian Signalyst DSC thread about the need of I/V converter. I think in that particular case shift registers form a simple voltage divider. That’s why I/V stage isn’t needed. It’s only my IMHO.
Pavel tried discrete output of his own design too. It was worser then transformer output stage. That's why lately he focus only at transormers output stage.
Frequency response of stock DSC v2 transformers 10 Hz - 150 kHz +/- 0.2 dB. That's why there is practically no LPF in DSC v2 from my point of view. In attach you can see DSC 2.5 measurements 5K+15K signal (DSD256). I have no problem with ultra sonic noise with my Prima Luna Dialog Premium amp and DTQWT by Troels Gravesen.
Output voltage 1.6V Rms. Zout ~ 700Ohm.
Ok...if this about right for the V2 as well, I would translate this for my tube output stage Design (which I need to get to 16Vpp as my 300b amp has only one driver stage): Do not use the transformers and attach the output directly to the grids of the tube with a grid to ground resistor to fine tune the output-voltage of the tube stage...which is how the Soekris DAC plays currently with it. Any issues with this ?
Hi guys! Can you disclose me connection process between PC and BB after Linux was booted from SD card with Botic image? I was not able to connect to BB so there is no possibility to record datas to eMMC. 172.16.0.16 address does not work for me. Thanks in advance.
Problem solved! You have just to check IP address of connected DHCP clients on your router and to use IP address of Botic7 client on your browser. Thank you Pavel
PPY`s ReClocker for BeagleBoneThat looks interesting Pavel. Will will boards be available or just gerber files?
Schematic diagram, BOM and gerbers are published on http://puredsd.ru
that's great !
Thank you very much ppy!
Thank you Pavel. I've just ordered 5 PCBs and a solder stencil - less than $20US including delivery!
I won't need five of Pavel's reclocker boards, two and a spare will meet my needs, so if anyone wants a bare PCB I'm happy to share a couple for just the cost of the shipping? Send me a PM if you're interested.
Looks like my order is ready to ship already.
Hi Pavel.
I'm putting together a BOM for your reclocker with references to Mouser part numbers as i plan to order the parts for my reclocker this week - the PCBs have already shipped from China. Do you have any recommendations for the capacitors?
I couldn't find any 220uF 16V 1206 footprint caps on Mouser, but they do have 220uF 10V 1206 tantalums, which I think should be OK.
I assume Tanatalum types for the 33uF 16V 0603 caps and ceramic for the 0.1uF (100nF) 0603 caps.
I can provide a spreadsheet of my BOM with the Mouser references if that would be useful - I found the BOM included on the schematic pdf a little awkward as you have to retype the part numbers into the Mouser website.
Cheers
Ray
Cheers
Ray
Ok. If you cannot find these capacitors, install these:
220uF tantalum can be used.
C9-10 33uF tantalum. C14-15 0.1uF
The spare boards are now taken. Sorry
Thanks Pavel. I'm sure I could find 220uF 16V tantalums with the right footprint but the cost would be disproportionate - much more economical to order the 10V from Mouser.
Ray
In BOM, I wrote the components that I had available.
Of course, you can use 220uF 10V. It'll be enough.
I see the 74LVC595 good to this project. It's have Iout +-50mA (x2 time compared to the old AHCT595), bandwith 180Mhz typ.
supply voltage - 3.3VI see the 74LVC595 good to this project. It's have Iout +-50mA (x2 time compared to the old AHCT595), bandwith 180Mhz typ.
Hi all!!!
I have measured the dsd test on version 2.5 and 2.6 with dsd 64. The results are as below! Did anyone ever see this! treble sound very much, please give me advice! thank you! and in particular I see some transformer for better sound.
- Digital Line Level
- Signalyst DSC1
