Shunt regulator +-15V
Its working perfectly..
10+22=6.8 Ω 1.113V-1.233
IRF510-9510 BF245B at 10ma 2sk170 China at 12ma
Many many thanks my friend. Damir.
Reactions: YashN
Updated schematic and BOM are here. To get better and more linear output impedance CCS (J2 and J3) is increased to about 10 mA and nfet used here should be chosed with the Idss of 10 mA or more. R2 and R9 are simple jumpers if Idss is close to 10 mA if higher then chose appropriate value to get about 10 mA.
Damir
Damir,
In my case R2 and R9 are 110Ω and measure on it about 660mv and 690mv . Must use simple jumpers on R2,R9 for better results?
Damir,
You have CCS current set to about 6 mA (0.66/110), better if you can increase it to 10 mA. Tray with 22R.
You can use jumpers too, it will get good result but there is no simple way to measure CCS current.
@dadod
I have completed one board after a long wait due to my travelling. With R3 and R12 reduced to 10K from 15K and a VR of 1K in the P1 position, i am able to dial in to 7.5V lowest.
Loaded it with 50mA load at +/-12V. Worked right away....thank you so much for this nice and compact PSU. J2 and J3 idss are 9mA and 9.2mA.
Reactions: dadod
zoom777, nice, it worked OK. 😉
I don't remember if I mentioned before why there two pins for + and - output, if load (or what you want to drive from this regulator) is not very close to the regulator you should use two wires for each + and - output from the regulator and shorten those two wires at the load.
