Sharp QA-2500 owners - please share your wisdom
need some help
Whats up gang? I have a 2500 with the diy projector company kit mk3. In order to fit the lcd into the case it needs to be disassembled. There are 3 boards inside, two are bound by a hard connection and the other (psu) is a harness. The way the case is designed unfortunately sucks for use with this lcd because either i need a longer controller to lcd ribbon, or cable that will replace the hard connection between the two boards that have that connector on it.
Its either that or i move the lcd tray up a few inches to compensate but i'm not sure how that will affect the optics and brightness of the display. any help appreicated
qa 2500 power supply from proxima
I thought I'd add my 2 cents. I'm using a Proxima Ovation 820 power supply for my qa 2500. It works great. Just cut off the plug, tin the wires, and insert into the holes(until you find a connector). The pin outs are as follows; looking at the panel : top left=+5v, top right=+12v, and both holes on right are rtn(ground). The other wire from power supply is unused. hope this helps.
regards,
tom
www.tomcarty.com
my mistake
hi guys, i'm sorry for the misprint. the +12v is bottom left pin when looking at the panel. I typed top right when the rtn or ground is both right pins. duh! so as it is looking at the panel, top left is +5v, bottom left is +12v and both right are ground or return. sorry. ta ta
