Hi Nanekiu
I am checking the Matrix website and I see that DSD is ASIO native (not linux)
Matrix Audio - X-Sabre Pro
Randy , I would sugest to check with diyinhk if there is an upgrade firmware because it seems to me the issue comes from device firmware.
Hmm it seems that matrix audio products are natively supported though looking at alsa/kernel commits done some years ago, it correctly detects the dac, and sends U32 DSD when looking at the Allo GUI.
Hi Nanekiu
I have asked the software team to look into it . Can you PM me the alsa'kernel links ?
Latest alsa updates I found for DSD is here: linux/quirks.c at f656891c66193345ee90b212b280d726792dc16c * torvalds/linux * GitHub but if the kernel in dietpi is relatively recent it should also have the same update.
My sparky usbridge doesn't seem to have these random soft pops, And messing with arm frequency seems to decrease the amount of times it happens.
Usbridge Sparky has a very old kernel . An older kernel might work better with your DAC , but thats not the issue.
Did you try to change the OS to see if its related to DietPI ?
At last please email me with your email and I will put you in touch with tech support
I haven't tried changing the OS yet, I know moode is a no-go as it doesn't have the latest libstdc++-6 required for HQplayer NAA, maybe volumio has the requirement covered.
My Email is: acesko92 @ gmail dot com
What version is required?
moOde 6.3.0 ships with the version below
Code:
pi@rp3:~ $ dpkg -l | grep libstdc++6
ii libstdc++6:armhf 8.3.0-6+rpi1 armhf GNU Standard C++ Library v3
I did try moode 6.3..0 the message I got when trying to install HQplayer NAA was networkaudiod depends on libstdc++6 (>= 5.2) no idea why it didn't work if Moode actually has a newer version.
It could be a bug in the NAA installer. Post the download link and I'll have a look at it.
Deb file URL for NAA https://www.signalyst.eu/bins/naa/linux/stretch/networkaudiod_3.6.0-42_armhf.deb
The .deb control file has what appears to be the correct Depends line.
moOde 6.3.0 (Raspbian Buster) shows that libstdc++6 is installed.
I'm not experienced with creating or debugging .deb.files but maybe the HQPlayer maintainer could take a look? I'd be happy to run whatever tests are needed.
-Tim
Code:
Depends: libasound2 (>= 1.0.16), libc6 (>= 2.4), libgcc1 (>= 1:3.5), libstdc++6 (>= 5.2), debconf (>= 0.5) | debconf-2.0
Code:
pi@rp3:~ $ apt list libstdc++6
Listing... Done
libstdc++6/stable,now 8.3.0-6+rpi1 armhf [installed]
Code:
pi@rp3:~ $ ls /usr/lib/arm-linux-gnueabihf/libstdc*
/usr/lib/arm-linux-gnueabihf/libstdc++.so.6 /usr/lib/arm-linux-gnueabihf/libstdc++.so.6.0.25
-Tim
Code:Depends: libasound2 (>= 1.0.16), libc6 (>= 2.4), libgcc1 (>= 1:3.5), libstdc++6 (>= 5.2), debconf (>= 0.5) | debconf-2.0
Code:pi@rp3:~ $ apt list libstdc++6 Listing... Done libstdc++6/stable,now 8.3.0-6+rpi1 armhf [installed]
Code:pi@rp3:~ $ ls /usr/lib/arm-linux-gnueabihf/libstdc* /usr/lib/arm-linux-gnueabihf/libstdc++.so.6 /usr/lib/arm-linux-gnueabihf/libstdc++.so.6.0.25
-Tim
Do you have an account on Audiophile Style forum?
If yes, then send "Miska" a PM. He replies quickly.
Matt
Maybe a really old one but I don't recall what it is and I barely have enough time to keep up with Moode Forum and diyAudio :-0
I'm thinking that maybe @nanekiu can broker this one. Miska can contact me via tim at moodeaudio dot org if he has time to investigate. I'm not ruling out some sort of bug or breakage in moOde OS with regard to this particular lib but I'm not seeing anything amiss so it's prolly going to take at least two heads to noodle it.
I reached out to diyinhk, but they said to make sure my i2s wires were not too long and also to reinstall windows.
I asked about an updated firmware, but they were silent on that subject.
It really doesn't feel like a xmos firmware issue either, since it works great with a PC running linux (using the hqplayer NAA image loaded on a usb stick).
Since I figured out how to set the clock frequency to eliminate pops at dsd256, I'm fine anyway.
Randy
This week , we were very busy testing and improving our products .
Revolution is advancing very well. Nirvana SMPS , we had a breakthrough.
Next week , I will make some announcement and maybe post some pics.
Any Updates?
I managed to fix the issue, I just needed to reflash moode, and lib 6.0+ got detected.
Any Updates?
We were very busy fixing issues on some new PCB , photos and announcements next week .
Is there a simple way to get the Shanti to output 7V? The outer pot can adjust up to 5.8v, and the inner pot doesn’t seem to have an effect on the voltage. A resistor or two perhaps, like the LDOVR modules have?
I know there is headroom because the transformer is 7.5VAC, netting about 10.5V. (I also discovered that despite being set at the factory for 230V, Shanti produced 4.99V in North America :facepalm🙂
- Vendor's Bazaar
- Shanti Dual LPS 5V/3A , 5V/1.5A
