Hegel H90 has good DAC when used with coaxial input, not so good on USB input.
It would be best to use an external dac with usbsignature player and Hegel's analog input..
From experience dac would have to be from class 1000€+ to see an improvement over Hegel internal dac. Or maybe Revolution Dac..
Hi hnnaum,
Thank you so much 🎶
We have the option for coaxial and usb or network play to the Hegel.
It give a pretty musical sound now.
I know the Dac can be better as in the Hegel, it is only as amplifier better.
We go for a other later,only I can live now with the intern dac from the Hegel inside... the sound is good for the money how it now plays. (with good cables)
The source(dac) is number one for the sound.
What is the revolution dac... I read it here in the topic.
Is it out.. or can I buy it 🙂
Hi Ioan,
sorry for being off topic – tried to drop you a mail just to find your mailbox is full once again.
Best
Stefan
Best
Stefan
Mark this one is for you .
La "Revolution" is coming . DSD 512 , USB input using Xmos . OPA 1612 output stage refined (datasheet is crap).
We are optimizing for SQ , THD+N at -114 tested (floor of our AP) unofficial -116 on RCA!!!!! NO ess hump.
Hi 🎶
I go oftopic sometimes 😃
I'm waiting on my Shanti power supply and usb bridge
Is there something already known about this dac.
When it's coming on the market for sale 🙂
I'm verry interested in this, For production date ... Revolution
Kind regards,
Ben 😉
Moode 5 will be available from our website today/tommorow the latest (with4.14 kernel)
We are working on a list of DACs (what to use on main ) and if your DAC does not appear there , you need to use kernel 4.14
download Moode 5.0 version with 4.14.92 kernel from below link.
http://3.230.113.73:9011/Allocom/moode/4.14.92-OS/moode-r50-rpi-41492.img.7z
This will fix any issues you have on non native linux DSD Dacs (with Moode)
Hi thank you for the link.
Only my package is arrived with the Shanti.. Only the have a damage.
I hear there is what loose inside...and see there is missing Miss a screw from the bottom plat
�� That sucks, so I thought a good Power lps.
Now we go wait.. what they say from my email on allo 🙁
Ooh it's fantastic service from Allo.
Tomorrow they shipping a new to me.
It comes from shipping... The post.
I'm happy from this good service.
Hi Vit,
Do you power just the USBridge with Shanti or you also power some of the Mirand DAC sections? If yes, which part of the DAC do you power with it?
Ciao!
Do
BTW, nice build!!!
Ciao!
Do
BTW, nice build!!!
Hi Do 🙂
PSU Shanti for USBridge and DAC . For I / V I used PSU from Salas, I also used PSU Salas 5V for USB Input.
BR,
Vit
BR,
Vit
FYI, found this link on native DVD dacs
GitHub - lintweaker/xmos-native-dsd: native DSD playback support on Linux for USB DACs
Last update was end of 2017. Guess it forked off somewhere else?
Hi Do 🙂
BR,
Vit
You could try the second Shanti output on the USB input.
Today testing shows that USBridge draws about 550mA. So its the same, you can use your PSU.. Still note that on power on there is a spike of about 850mA for 200mS
Hi Ioan,
is that still valid? On audiophilestyle it's said that USBridge sig will not work with a PSU of 1.2 A or lower and 1.5 A is recommended at least:
ALLO USBridge Signature - Page 12 - General Topics - Audiophile Style
Can it be that a minimum of 1.5 A is necessary if none of the power cosuming things such as HDMI etc.is turned off? Would it be possible to get it down to the above mentioned average consumption of 550 mA and 850 mA peak at launch, when HDMI, USB etc. is turned off?
Best regards
Stefan
In fact we recommend 3A , same as RPI 3B+
We did measure 550ma but that was after boot. Note that we had reports of people using it with 1.1A (but not tested by us) that had under voltages.
There are many ways to save power , we did not test all cases.
We recommend 1.2A as a minimum .
This week , we were very busy testing and improving our products .
Revolution is advancing very well. Nirvana SMPS , we had a breakthrough.
Next week , I will make some announcement and maybe post some pics.
Great news , looking forward to both products
Hi guys,
I received my usbridge sig with moode os preinstalled. I installed the digione sig as hat then booted it up. This is connected via Ethernet. I couldn’t get it to work. Was able to find out ip address via my router. So i tried moode.local and ip address but will not open on the browser.. I’ve also tried my dietpi micro sd card from my digione sig player and still does not work using dietpi.local. Green led in front is blinking as well as the red led.. verified that i have connection via Ethernet using other laptop.
Please help... i will try ropiee later when i get home and see what happens.. any suggestions?
Try Microsoft Edge I had the same problem with Microsoft explorer.
I use Ropieee installed on the usbridge signature together with the digione signature hat, roon rock on the nuc8i7beh.
Power supply I use the shanti.
Regards,
Rudy
Regards,
Rudy
- Vendor's Bazaar
- Shanti Dual LPS 5V/3A , 5V/1.5A
