Hi, I want to try putting the Seas FA22RCZ in a cabinet, been using it OB until now. Can anyone recommend the best cabinet ? There seems to be several types; the SEAS Haavar one,
http://www.seas.no/images/stories/prestige/pdfdatasheet/fa22rcz_appnote.pdf
or this triangular offering 2A3 posted:
2A3 Maniac: Hochwirkungsgradlautsprecher: Offenes Gehäuse mit Seas FA22RCZ - der Bau
Are there any others that I have missed ?!
Marcus,
If you´re looking for a simple solution you even can try an open baffle. Seemingly not a perfect match with view to the relatively low Qts but in practise working surprisingly good:
Triangular open cabinet:
Now some very promising measurements of the frequency response are available, strongly depending on the position/distance to the rear wall:
Carsten
Carsten
thanks Carsten, that's interesting and great frequency response ! You must have them quite near to the wall I imagine.
I am using them in open baffle at the moment, but need a sub:
There are some interested cabinet designs for the X1-08 EXOTIC F8 ( I think it's for this one, not 100% sure):
Has anyone any info on this design ?
This design is for this driver, and I have no doubt that it will sound excellent!
Ok thanks, looks the part, have emailed Woden yesterday to see what they say just to make sure.
Ok thanks, will give it a go, after all its only a sheet of plywood to find out
If you build Scott's ML-TL I doubt you will need a Sub-woofer as they will be tuned to 30hz!
Larry
Sounds good Larry ! Anyone got the dimensions ?
http://www.diyaudio.com/forums/full-range/180014-seas-fa22rcz-full-range-project-23.html#post2708387
dave
I am planning on building a open baffle using a SEAS FR22RCZ. I have a spare KEF C45 (8" in sealed box) which I intend on using to drive the bass.
Overall configuration might look like this. The SEAS will drive upper bass and mids. The KEF C45 will be used to handle low bass (sort of using it as a subwoofer). They will probably be driven by different amps, with something a bit more juice for the KEFC45 and something more refined for the SEAS.
I have some questions on this.
1) Does it makes sense to have a open baffle for a full range speaker followed by a sealed box for another speaker. Does it negate all the nice benefits of a OB?
2) I am probably going to impliment an active crossover. Should I cross for both the speakers? Or should I just cross for bass unit, leaving the full range to run full range? I don't need it to go loud.
3) My intended dimension for the baffle is about 90cm high and about 30 cm wide, the speaker place approximately 2/3 distance from the bottom.The baffle will then be stacked on top of the KEF c45, to form a floorstander approximately 5' tall. I might supplement the high end with supertweeter.
Incidentally how do you find the SEAS FA22RCZ for use in open baffle, compared to other drivers such as Fostek etc?
I am a newbie in OB design, but I've dealt with a few fullrangers, fostek, markaudio etc.
Any words of advice is kindly appreciated, no matter how basic it might be.
Oon
Oon
Oon
Oon - "full-range / wide-band" drivers are often selected for use in OBs with woofers - this particular SEAS is somewhat larger than those usually implemented, and based on your comments in other threads, you might find them lacking in the top octave or two.
The most common approach I've seen with these types of projects has been running the woofer(s) - ie sometimes 2 per channel - on the same OB as well, but there's probably no reason not to a least experiment with sealed bass drivers - particularly as you already have something on hand . I think how much OB benefit you'd retain would depend on the selected XO point - start experiments in around 200Hz
If you haven't experienced an OB system before, this would certainly be a quick taste test. Keep in mind that for a variety of reasons they (OB) don't work for everyone .
Active XO and bi-amping is certainly a very flexible approach - with sufficient power and level controls on each amp, differences in driver sensitivity become moot.
I'd still be inclined to HP filter the wide-bander to improve power handling / reduce excursion problems.
- Full Range
- Seas FA22RCZ full range project
