Seas FA22RCZ full range project
... please could you tell us a few words of the result (sorry..I´m not the specialist for reading diagrams...)
Hi Karten
very short:
both graphs, the black (Gradient AX8) and the red (Seas FA) are nearly parallel in all grafs. This means: both drivers should give nearly the exact performance in that enclosure.
Slight differences in impedance - who cares ?
or max SPL: here the Seas is "better" - probl. higher x-max ?
Don't care about the "high" towards deeper frequencies - it's a simulation, that excludes the effects of the small baffle-width.
The measurement (follow links) provide a perfekt fit.
Here is a picture of the modified SEAS wideband, a view into the multichamber cabinet and the reflex tubes.
With EnABL you really need 2 to fully appreciate the difference as it has to do with increased downward dynamic range improving the 3d soundstage.
But still, one has to work with what they have.
dave
I obviously have two drivers, but I thought if I treat both of them at the same time then it might be difficult to give a fair unbiased evaluation of the modifications. That is it won't be possible to do an a/b comparison.
True, but mono vrs mono won't tell you anything about one of the largest beenfits of EnABL.
Treating them both won't allow any direct comparison.
dave
Hi Karten
very short:
Hello Joern,
thanks...I understand yozr message.
regards
Karsten
Scottmoose:
How critical is the enclosure volume as outlined in first post? If I brace up the enclosue as recomended by planet 10 do I need to increase volume per the bracing?
ML-TLs are usually pretty tolerant. If worried and if you use 18mm material, increase the width by 12mm.
dave
