Sealed subwoofer to bass reflex, what do I gain and what do I lose ?
Ok, I guess I'm a bit mentally inactive and chess just bores me 🙄 , so I'm playing with Win Isd to see what would happen if I converted my two sealed subwoofers (which I built and documented here at Diy Audio ) to bass reflex ...
So I will upload different graphs and ask about the opinion of the experts.
Reactions: DblAA
The current sealed cabinet is approximately 122 liters, this volume includes an average virtual increase between 15 and 20% when fully filled with polyfyll .
This is the FR curve.
Good question. I've dabbled in this for a while.
My 'general' observations:
  • sealed boxes offer a 'cleaner' sound (less affected by port turbulence etc)....so maybe better for hi-fi/music listening vs HT applications
  • ported boxes offer lower frequencies (for the same driver / box size), so better if you don't need to overly EQ a woofer in a sealed box to obtain the same result.
  • ported boxes to have a different sound, less 'tight/dry.'
May I ask, is your main listening two-channel hi-fi or home theatre/stereo combined?
Have you considered different room placement for the existing subs to see if this gives a noticeable improvement in sound quality?
Of course, if you wanted effortless/rich bass, you could consider something substantial like a tapped horn or a Bill Fitzmaurice Tuba sub..., which I can attest to.
Reactions: BP1Fanatic
It's a prosound (bass) horn driver spec-wise, nowadays more often used for small, high power prosound mid-bass BRs, so has a naturally high box tuning.
Precisely because of what you say, Eminence did not make "Sealed" construction graphics available, it directly appeared N/A.
He is a 4 layer voice coil driver, I emailed Jerry from Eminence and he explained that detail that was not in the specs.
Your assessments are correct and I know them.
At one point I used it for both (HT and HI FI), now only music, but I ask you for a little patience, let me develop the idea, now comes the best, the comparisons that may be more important than FR, such as delay group, VC excursion and power admission.
Thanks for responding so promptly.
Are you adding any EQ to the sealed subs? If so add that to the simulation and recompare group delay.
As for tthe boomy bass comment that entirely depends on the combined box/room response, a well integrated sub should just extend the systems lowend respose lower regardless of type.
Reactions: KaffiMann
