Same outputs shorting each time
I would cut through it. I don't know what sort of tools you have. I've recently been using a plexiglass cutter. If you have one, try it. Otherwise just get through it however you can. If you can tell which side the carbonization is on, start on that side. You only have to cut until you break into clean fiberglass. You don't have to cut all of the way through.
I would have to repair the other amp. I may have to do that just to test the boards.
Just double checked. Q122,123,126&127 are MPSA56
Q120,121,124&125 are MPSA42
Q114,116&118 are MPSA92
Those are the only ones I removed. Checked all the others in circuit.
Driver boards are working.
Do you read 0 ohms between the two grounds (PG and SG) on the driver board when it's in the defective main board?
If you are checking without the driver board in the amp, you need to place the meter probes on the side of the board with only a pad (not on the side with the trace leading to the pad).
"Do you read 0 ohms between the two grounds (PG and SG) on the driver board when it's in the defective main board?" - Yes. Double checked it.
Everything points to the driver board as the problem but the boards run correctly in the test amp. I'm scratching my head. I don't know what's going on or what to check next. I cut the low side drive trace to isolate it from all the gate resistors and diodes. Signal was the same off the driver board. Tis a mystery indeed.
Is the amp working? Do you have output?
Did you have to repair the output?
It's unusual for just a couple of outputs to run hot on this amp. Check the driver board closely. Reread this post starting at #55.
If you have a scope, check your high and low drive off the driver board. You can see what the wave forms should look like in this post. I've posted pics.
Be sure and check the gate resistors and diodes to the outputs. You will have to unsolder the diodes to test them properly.
I'm sure someone else will offer up advice. Good luck.
sorry being late.....i ll check again....the power supply was blown up...
now is working fine....i have checked the gate diodes and resistors...i have also checked the driver boaed but is still getting hot....with no output fets is getting hot in about 15 seconds...
