Salas, do you think I should use a 21vac to output 22/24 volts?
If so, I will use my 18vac and set the shunt to 18.
The Boozhound jfet board works from 12 to 24V.
The important now is this :
I soldered new Q2 and Q3. They still measure 0,62V.
Taking a closer look to Q1 and Q4, they are BC327, not BC337.
This may be the original cause of trouble.
So, get to solder those BC337s.
Same thing with Boozhound shunt. Q2 and Q3 are to high, 0,62V.
Q1 and Q4 are BC327. Arrrggghhh...!!!
There are two more shunts, +/- 5volts, for analogue output. The pos has BC327s but the neg has BC337s.
This kind of error reveals one of my strong weekness. I look a lot for details, but not allways for this kind of detail. We learn and improve to our last minute...
Mouser sold BC327 and BC337 in the same package, the package for BC337.
I confirm all resistor values, They made mistakes before with mo orders, I saw the references in the transistors but did not pay atention for this subtle difference, 227 or 337... they look the same.
Well, I am not sure that this is the cause, I hope so.
I made some research and figured out that although 327 and 337 can be considered as equal, 327s have a higher output voltage.
Is that possible that Q1 and Q4, being 327s, affect the voltage in Q2 and Q3?
Q2V and Q3, 6,2V !!!
You originally wrote 6.2V. 0.62V is good. But they must also be the right types.
Do that. Use 18VAC for 18VDC.
They are PNP and NPN type versions. Use the right types in the right places exactly as in the schematics.
Sorry! Wrong vale, it was 0,62. My fault.
When you say the right types, ok I understand, but about BC327 or BC337...
are they from the same type?
Do I have to desolder BC327 and solder BC337?
BC327-BC337 are of the same line complementary PNP & NPN types. You have to read the schematics in post#1 or in the pdf guide and use the right type number noted for each position for each polarity regulator. Use a magnification glass and good light because the letters on those parts are rather faint and very small so its easy to mistake 327 for 337 parts and vice versa.
Ok, I wanted to be completely sure about that. You are right, in the end it is only a matter of following instructions. We (me) have the tendency to complicate, in the learning process.
Your patience is appreciated Salas! I am finalising this project.
My shunts look beautiful and the handmade heatsinks look gorgeous. Now I have to order those transistors and that's it!
OK. Wishing you complete success and post photos in the end if you like.
Yes I will. Thanks!
Polaron, simple thing to remember is:. All BC transistors in this regulator are PNP for the positive DC output board. And all BC are NPN in the negative DC output board.
PNP: BC327, BC560
NPN: BC337, BC550
PNP: BC327, BC560
NPN: BC337, BC550
PNP: BC327, BC560
NPN: BC337, BC550
Right! It is already in my memory, because I saw them so many times...
I can even order without the manual.
Again, I measured everything, all transistors, all shunts and evrything is ok and no mistakes. I only want to change two BC327 that are not in good shape, not looking well.
All heatsinks get only a litle bit warm, long life to the shunts!
With how specific the the choice of C3 is, Is there times where you need to pay attention to decoupling caps in the circuit you are connecting the ultraBiB to? Especially if the regulator is in very close proximity with basically no ESR between the reg and the load
Sorry if this has been discussed before, not being able to search 2 letter words (''C3'')is a real hindrance.
In my experiments decoupling caps down the rail did not disturb the reg (either small film or higher lytic values) as long as there was few cm physical distance between those and the reg's output connector.
Ok, good to know. Now to see if there is still any audible benefit to leaving the existing caps in the circuit coming from typical ULN LDOs, including lots of 10uf oscons in parallel and very large polypropylene DC Link film caps
Hello everybody. I'd like to share some good information with you.
Some of us were struggling to find PF5102 or to replace them for J113s, but we must select the 113s to 10mA. I found a link were you can buy many pairs and quarters for a very good price, selected to very small values.
What do you think about these J113s and PF5102s? Check this :
JFET Matched Sets - Stompville Shop
BTW, my four Ultrabibs have PF5102, but they were not matched. Should I live them or install matched ones? Thanks.
You can by 5102s not matched here, they have stock. There is also a Vfet matcher you can buy, with a very good manual, so we can be autonomous and stop buying matched fets like we were buying diamands.
Matched are not doing any harm. But they are not a must in this design. When their IDSS goes only up to about 10mA they are still OK with the 270 Ohm standard BOM source pin resistors value (R4 R7 R8).
So If I buy PF5102s do have to select them to 10mA, right? Does it means that they can have any value below 10mA? I need to know what to do best...
- Power Supplies
- Salas SSLV1.3 UltraBiB shunt regulator
