would these setups work?Hiya fellows, I'm going to do some jfet matching for some 2SJ103, 2SK170, etc. I would like to know if the below schematic is appropriate for my purpose?
Don't know, never used anything device special. A 9V battery a small resistor, DMM, and Ohm's law proved enough for just IDSS.
Yes. That little circuit looks like its for matching Vgs(off) spec. Its the cut off voltage of a Jfet. So lets forget that. What we need match here is IDSS. I.e. top current when fully on with Vgs=0. That's the way we use it in this buffer, that's what we look for. So get yourself a 9V battery, a 10 Ohm resistor and some small crock leads. From left to right as you face the flat face of Toshiba 2SK170 you have pins DGS. Catch the two last ones to the right with a crock clip together and connect the other crock end to battery (-).
Now catch the left alone pin D with another crock clip and connect to the 10R on the other end. Connect the free 10R lead to battery (+) in a couple of minutes after you had touched the Jfet to let it lose your fingers heat. Now full IDSS current runs through. Use your DMM on DC voltage mode and autorange. Note down the reading across the resistor after it settles in a bit. Unhook that Jfet and stick it over that reading on paper. Next one ditto. After you got 'em all written down calculate currents from I=V/R. V=your note in V or mV, R=your 10 Ohm resistor or anything in hand up to 50R, I=IDSS. Make pairs of the closest ones. Use two good pairs of a nearby mA region to assemble your DCB1's audio section. Send me cherries.🙂
Thanks!
Your method of matching Jfet's surprised me at its simplicity. I used it to match LED's also. You've helped me immensely and I am in your debt.
It all fits with something I try to live by." A day where you don'y learn something new is a wasted day. "
From what i've read for the buffer part Takman resistors are a good choice but wich one carbon or metal ? I'm preparing an order to pcx and i want to know your opinions.
Thanks!
Thanks!
I liked the AMRG resistors from parts connexion - an improvement over Takman, I think, and not outrageously expensive. They don't fit too well though.
I've just ordered an 80 ma toroid from Richard sumner in Toronto, potted, to start the ball rolling on this build.
Was considering this pot, but it's only 10K and carbon to boot.
KKB1031S28 Precision Electronic Components Ltd | KKB1031S28-ND | DigiKey
Any opinions? Would a goldpoint 20k be that much better?
I'm pretty much a newbie doing these things, having only built a couple items, but my question here is -- the BOM calls for a pot from 10K to 20K. The original B1 was 25K.
I'm a bit confused as to what value to use, and any help would be very appreciated. My readings of the threads are inconclusive, if 10K, 20K or even 25K is the "right" value.
Thanks in advance!
Thanks in advance!
The lower value between 10K-25K your source equipment can afford loading wise the slightly better its going to sound.
Excellent, thank you!
The output impedance of the phono section that will be playing into this is 55 ohms. 10K makes for a input/output ratio of 181.8. That should be fine.
That opens up a LOT of potentiometer options, like TKD.
Ive read that matched LEDs are, and are not necessary. Now is this for Vref? or CCS?
I'm just figuring all this stuff out. And also Does it matter if I have more than the required V all my LEDs measure at between 1.895 Vf and 1.915 Vf. So 5 x any of them will be more than 9V for Vref and 3 x any of them will be more than 5.4V for CCS. Or should I just stick'em on the board and not worry?
What sort of heatsinking is necessary for the DCB1 running @ 600 ma?
Is the floor of the enclosure plus spreaders good enough, or do we need to use amplifier heatsinks?
Does the enclosure need to be ventillated?
~1.5C/W per rail for two Mosfets each or better. Ventilation of course. Your criterion should be no more than 60C on metal with any sinking plan.
I'm not sure I understand. 1.5 C/W each mosfet ? Or 3.0 each mosfet and 1.5 for both connected to one sink?
If 3, then board level will work, otherwise they start to get BIG
Thanks.
Thanks.
1.5W/C parallel sink per side bolting the side's 2 Mosfets to it, or 3W/C per Mosfet.
Excellent! Thank you!
That should be enough to buy all the external parts! Hopefully, I can find some the fit!
Cheers!
Maybe this?
http://www.aavid.com/products/standard/530002b02500g
Cheers!
Maybe this?
No, get sink with flat back surface side mounted along the PCB edge. Something like this that can accommodate both Mosfets each side of the PCB.
SK 92/100 SA - FISCHER ELEKTRONIK - HEAT SINK, 100MM, 1.4°C/W | Farnell United Kingdom
- Analog Line Level
- Salas hotrodded blue DCB1 build
