What muse did you get? I just received a box from Academy. It has instructions to mate it to BA 2018, what changes if any did you make using it with DCG3?Well spotted . The third is for the muses volume attenuator and input selector board.
Russellc
Unfortunately I have not been able to get it to work. Please let me know if it is worth the bother 😉What muse did you get? I just received a box from Academy. It has instructions to mate it to BA 2018, what changes if any did you make using it with DCG3?
Russellc
To create symmetrical voltage from bench PSU you select series mode. The master channel settings are mirrored. The user's manual explains which output posts to connect as +/- and midpoint.
I am not sure on what exactly you want to test though. Please elaborate.
Alright. That's a valid way to test PSUs when without transformers. AC rectification section is being skipped. You should connect the incoming DC at suitable points after the bridge diodes.
When having transformers the simplest current limiting device is a good old dim bulb tester between them and the mains.
- Analog Line Level
- Salas DCG3 preamp (line & headphone)
