Salas DCG3 preamp (line & headphone)
diyAudio Chief Moderator
Joined 2002
You got to always mind the power up/down sequence for transient cycles then. Make C1 15pF also to cut on bandwidth because its going to go even faster internally on higher rails. An OPA2604 can take +/-24V max for U1. R6=3.3k will allow it gain for near 44V pk-pk on 2V input.
Joined 2002
49C won't pose any danger to the sinked transistors. The electrolytics around there are all 105C also. Does the lid have ventilation holes over the sinks? You would surely prefer 40-45C though. Feels better. Ok the transformers are over nominal voltage but is it on the high bias setting too?
Joined 2002
On Q1 Q2 mirror BJTs yes, we did that often here. For J1 J2 uPA we didn't try sockets though. Its not a phono stage on the other hand, shouldn't be sensitive to socketing.
It could be handy if planning to listen with alternative LTP JFETs (J1 J2).
In any case and for any parts see to achieve oxide free and firm contact to female socket pins though. Shorter legs help the parts stay firmer.
For quality contact use a lens under good light and clean the parts pins. Because there will be no soldering for its flux to automatically clean them somehow. Almost all the candidate JFETS are NOS. Their pins should be oxidized enough already.
Joined 2002
VA you mean not mA?
The extra Tx for the selector can save on chances of ground loop low level spikes when you don't monitor the result with FFT analysis so to tweak the cabling etc.
Due to better power source separation. You could achieve a fine result with a tap from DCSTB's raw DC to I-select DC in though. Especially useful when short on box space.
