SA2015 V-MOSFET Builders
Amplifier comparison
Hi thimios!! What about this amp? It's better than Peeceebee?
SA2015 is a complete amplifier comming with a very well documentation,using common parts.
Music reproduction is at very high clase.
Better amplifier isn't something that all of us can agree.
This requires an extended number of blind test in a well insulated room,Using top quality speakers and a number of << golden ears>> listeners
Sorry i can do nothing about this.
I'm building,testing,publise the results,fine tuning if nessecery.
I amn't good into bla-bla.😉
If you personally haven't heard, you never know nothing about!:nownow:
Just my opinion.😉
Starting the wiring
I'm about to start wiring the amplifier.
I have to examine two options.
First option,all the wires on the base plate.
Second,all the wires under the base plate,between the base plate and bottom aluminium
cover.
The second option give more clear inner look but good hole isolation materials required.
Opinions please....
SA2015 Wiring
Given that a lot of 230V A.C cables are on the top it seems that d.c cables may be stay on the top too.
SA2015 Wiring
My first care is putting the toroidal as far as possible from amplifier's input.
As i can't find a better solution i will try the previous configuration, if this fail(audible hum)i will try to rearrange the trafos.
I haven't chosen where is the front and where the rear panel yet.
toroids directly behind front panel. amplifier outputs show to front panel to keep the inputs far away from toroids but short to input terminals. housekeeping circuits above toroids or near back panel or between power supply. vertical iron shelfs between amplifier and powersupply/toroids.
Some mechanical progress
A few pictures from mechanical progress
Just my opinion.😉
Ok, very correct from you!
