Rockford Fosgate T2500-1bd
You need to confirm that each of the sets of contacts are clean if you don't have a replacement. The image is for a 4 position switch but positions 2-4 are the same. Your switch is double this one. Confirm that you read 0 ohms between the two bridged contacts for each position.
Between pads 1-8 on U106 I get 6.28M ohm
I used jumpers instead of a switch and the problem is still there I get 13 volts on pin 1 of U106 . I jotted I had voltage on the pads for the the master slave switch .
But I’m not sure where the voltage is coming from on the pads for the master slave switch which is causing the issue
Ok I pulled the EQ card out of the amp and then voltage issue went away .
There is an ic on the board wondering what the likeliness of it being bad is ? The master slave switch connects on one of the pins on the ic wondering if that’s causing the issue
You posted that you went back to a point where you had voltage. You would have wanted to go back to where you had good clean audio and then introduce ONE change at a time, checking for a change.
The DG201 is a switch used to select between local or remote bass control.
Was the telco-jack shorted (pins inside) on the other card?
Back to this amp . I tested it and worked fine for 2 hrs with 0 issues . Give it back to the guy he hooks up 6 sub woofers to the amp and blows the outputs . Do all 8 outputs need to be replaced ? It blew 4 of them out of 1 of the banks . Can I replace the 4 or should I replace all 8
