rockford fosgate t15002 amp troubles
seems some voltages are either fluctuating or flashing now. light stopped double flashing, and 30 amp fuse blows now, have to resort to the 200am fuse it came with.
U3
Pin 1: 4.6
Pin 2: 17.5
Pin 3: 18
Pin 4: .17
Pin 5: 2.38
Pin 6: 4.73
Pin 7: 4.96
Pin 8: .589
Pin 9: 5.4
Pin 10: 1.5
Pin 11: 1.5
Pin 12: .004
Pin 13: .5
Pin 14:4.94
I'd like to use a current limiter in the B+ line but it would probably be too costly. If the outputs only get warm after 10 minutes, it may be safe to continue testing. Power up the amp and measure the DC voltage (down to the millivolt, 0.000v resolution) across each of the 0.1 ohm resistors in the repaired channel. (place the probe on each end of the resistor when measuring the voltage. Post a list of the voltages, re-check to see if they change more than ~10% from the initial readings. Polarity (+/-) isn't important here. Only be concerned with the value.
weirdly, testing some of the voltages changed the frequency that of the led flashing.
all voltages were flashing from 000 to posted voltage. and some were - voltages.
1:.007
2:.007
3:-.008
4:-.007
5:-.006
6:.007
7:.017
8:.016
9:.015
10:.017
11: .013
12:.019
channel one showed NO voltage on nearly all resistors but maybe 2.
It's strange that half have ~2x the current through them. I'm assuming that all of these resistors are new.
With no power applied and no speaker load connected, what's the resistance across the speaker terminals for one this channel? If you can't get a steady reading, clamp the probes in the speaker terminals.
With power applied, what's the DC voltage on this channel?
For Q2036, make sure that you don't read anything near 0 ohms between the three legs of the transistor and the the three legs of the 3-legged jumper to the right of the transistor. Check all combinations.
Also confirm that you have three 0 ohm connections between the terminals of the surface mount transistor just to the left of Q2036 and the 3-legged jumper. none of these should be shorted together. Confirm that none are.
This one (circled).
