rockford fosgate t15002 amp troubles
k, also i went back and tested all remaining fets, all 28n15 tested fine, all 36p15 gave a negative reading in the 200m ohm range on leftleg center leg, a no reading on left leg right leg, and a good reading on right leg center leg, should i be concerned?(also went and tested the shorted ones and confirmed they r bad.
will let you know what happens with resistors, thanks
alright thanks, i tested the smd after removing the adjacent .1ohm resistor and got same reading, so i decided to test the smd next the the .1 ohm resistor i just now removed, measured 24 ohms, within tolerance, yet the one adjacent to blown fet still wont read anything but about 37 ohms. does the smd need replacing?
also should i be worried about the power/input side of the board, or does everything seem okay there to you?
also, i have having some issues finding the resistors 20r0 and 37r4, i checked future, they have 0, is there anywhere else i can check, also check online components.
They should be 0805s. Wait until you get the diagram, it will tell you what size they are. There is a suffix on the part number on the schematic diagram. The following show the various sizes:
B = 0805 (0.080" x 0.050")
C = 1206 (0.120" x 0.060")
D = 1210 (0.120" x 0.100")
The image below is an example from a different Rockford amp.
