Rockford Fosgate Punch 601S
On 1 side of R16 I get 20.66 volts the other side of that resistor I get 0.62volts
On 1 side of R25 I get -19.34 volts and 0.62 volts on the other side
So I think the value of the resistors is to high .
Should I gradually lower the value of 1 resistor to see what the voltage is on the opamp ?
Say start with a 470 ohm and see if I get voltage on the other side of the resistor
In post 7 they were open I replaced them according to the schematic now I get no voltage at the opamps .
In post 7 they were 100 ohm resistors I replaced them with 1k resistors since that’s what the schematic shows goes in those locations .
I put the 1k resistors in according to the schematic and not the picture since everytime I power the amp up it would burn a lot of resistors so I thought the value of 100 ohm may be wrong
Sorry my mistake they do heat up before the mute delay ends .
I still get 20 volts on 1 side of both of them and 0.62 volts on the other side of them
Also C305 in post 7 was a 20uf cap . I replaced it with a 100uf cap according to the schematic
