Rockford Fosgate Punch 601S
At the opamps I get -18 volts and positive 17 volts .
At the regulator I get 50 volts on all 3 legs still .
R310,311,313 I get 50 volts measured directly across the pads
R211,210,213 I get 20 volts measures across the pads .
So I’m assuming this is why the resistors are burning up .
Is it normal to have correct regulated voltages at the opamps but 50 volts at the regulator ?
From pin 8 of the opamp to middle pin of the 317 : 2.460k ohms
If I use the amps ground terminal as reference I get the following voltages on the LM317
Pin 1: 44.6 volts. (Adjust)
Pin 2:47.2 volts. (V out)
Pin 3:50.5 volts. (V in )
On the opamps I get
Pin 4:-18.5
Pin 8:-17.9
