Rockford Fosgate Power 400a4
All measurements: 0.1 V/Div 5 uS/Div
Using probe ground on non-bridging speaker terminal as reference.
No treble boost on this amplifier.
Adjusting gain does not change anything.
Low pass and full pass positions do not change anything.
Yes, it flattened out to resemble Ch 4 above then as soon as the P.S. ammeter bumped up it changed to the image below and stayed that way until I cycled the remote.
1.05 mV across the resistor in image, after I cycled the remote the voltage across the source resistor read 0.04 mV although the pot was not adjusted.
0.1 V/Div and 5 us/Div
I didn't do anything to the power amplifier section on this amplifier, other than the two source resistors I replaced last night in Ch 4.
I replaced the power supply FETs and the 2G Transistors Q2 and Q3 in the power supply.
The output FETs may be original, 540s and 9540s, I really couldn't see any evidence that they were changed before.
I did test them initially for shorts when I first got the amplifier.
I have a Fluke 187 that will measure capacitance, but I'm not sure how well in circuit.
I also have, if you squint real hard, you might loosely call an esr meter (MESR-100). It is supposed to test esr in circuit and I have actually identified bad capacitors before in circuit. It also seems to work okay when comparing known good capacitors to other capacitors of the same value that are in question.
They are all smd components so unless the resistor would stand a better chance of resisting damage by removing and re-installing I will just remove the capacitors to test. I guess it's six of one and half a dozen of another.
What do you think?
