Rockford Fosgate 160A2 doesnt power up
i put old resistors in, i dont have new ones.
i dont know what happened and how reliable this is. i measured those gates from leg to R233 R260 and they looked ok.
im planning put amp in and play it full throttle, maybe some switch to speaker wire if it plans to go negative rail again
after post #53 is made with newly soldered resistors, i think idle was up that first test
Did you adjust the bias current and confirmed that it held after the first repair?
Did you use parts from a reputable distributor (not ebay/amazon)?
Did you replace both Q119 and 115?
Did you tin the backs of the replacement FETs before soldering them to the MEHSA strips?
