Rockford Fosgate 160A2 doesnt power up
well, legs are cut. im not good at trying to take it out when theres three thick legs on board.
yeah, only done is outputs changed and q210 q110 pushed close to heatsink with paste
In the future, heat the MEHSA strip from behind and lift the transistor and stand it straight up. Then apply new solder to all 3 legs so that you can lay the tip of your iron across all 3 legs (heating all at once). The transistor will generally fall out of the board.
Do you have positive and negative rail voltage?
Do you have positive and negative regulated voltage on the power supply pins of the op-amps?
