Pano, I've heard from others too that Gary's system is astounding - is he still using an SS Tabor as his main amp or is now using a tube amp?
The Echo is external, Firewire. The M-Audio is PCI. They both have spdif inputs and analog outputs.
When I last heard Gary's system the mid-high amp was still the Tabor. It's basically a tube amp with transistors.
It is really simple, to be honest.
Before attempting any given test on an unknown quantity one tests known ones.
So if for example I wish to examine the effect of a given digital domain modification on the analogue output, I would carry out the test using either calibrated and well maintained gear with a known confidence limit (e.g. A Miller Analyser or an AP2). Failing that I would use a loop-back test or use a known good comparison item (e.g. a low jittere CD Player etc.) to establish the confidence levels.
And I would select a test regime that is appropriate to the area effect I am expecting.
In the case of the SPDIF attenuators etc. here we can be clear that there is no data-manipulation (oversampling, ASRC etc.) in the device itself, however we do have to make sure that the Computer the device is attached to sends bitperfect data, which is surprisingly hard to achieve unless using ASIO or WASAPI exclusive mode.
Based that we know that there should be no data-manipulation we need to test for jitter. Of course, we could compare THD, but even a few nanoseconds jitter seem to leave the calculated THD & Noise in both RMAA and on an AP2 essentially unaffected.
So it follows that we need to use a test that highlights jitter, or as it commonly called J-Test. In order to get measurements that give confidence I need to get the AP2 at the Lab to run large numbers of FFT's and average them to reduce the AP2's own noisefloor, so a single jitter measurement that has a sufficiently low noisefloor and hence a high enough confidence level may require 1024 averaged FFT's that take over 30 seconds each to run.
If we instead wanted to conduct a listening test, not a casual one for personal use, but one to publish and to attach any significance to, I would feel incumbent on the experimenter to first conduct some tests on items that have a known audible difference, to ascertain the lowest level of sensitivity.
Stimuli that may be employed in the "calibration tests" include reversing the polarity of one stereo channel (you may be surprised how many "flunk out" at that test), a channel level difference of 1dB and of 0.3dB etc. That way we can have at least confidence that our test resolves known audible differences (again, you would be surprised if you knew how often such is not the case).
Finally, while designing my test it would be good to employ assumptions in our statistics that ensure the risk of type A and type statistical errors is equalised, which is a great problem with small scale listening tests.
Based on my own experiences in such tests I would also suggest that the numbers of trials in a row is limited to no more than five, as with many individuals attention and acuity falls off with much greater numbers, something that can also be tested during the "calibration" phase (e.g. make the same test with 15 trials in one run or three runs of five trials).
I actually found my work on establishing the sensitivity of my tests by far more interesting than the tests and results themselves (which where needed for commercial reasons), especially the way in which they illustrated exactly WHY, as one proponent of ABX/DBT testing remarked "perfectly obvious differences when testing sighted evaporated when the test was done blind".
Actually the differences did not evaporate, they where still there, but the blind tests and attached statistics simply pushed the "noisefloor" up so much that previously clear differences where obscured, at least to the eye of the statistician and the ear/brain system of the participants.
So, my point in all this is that there are ways to test seriously and then there is simple vanking around, which can be fun but is ultimate futile.
A serious test demonstrates first what it can and what it cannot resolve, that it has sufficient resolution to show the debated phenomena and the result of testing a "known good". All this serves to illustrate what the test can resolve and what not and sets the limits and thus provides the context within which the results may be interpreted.
This last item of testing a "known good" item is included ideally even when the test gear itself is "known good", as it will highlight any issues in the test that may have escaped the attention of the person doing the tests. I had several instances of magazines testing my gear using also an AP2 (plus where the Testers had used the AP for many years on a very regular basis) and coming initially to results that where dramatically divergent from those that I got. In all cases we were able to resolve as being due small fault in the test or interpretation, be it faulty calculations outside the AP2 or simply issues in the test set-up.
Ciao T
2 posts so far and no details.
Ciao T
I don't know about the Echo - I would have to research it. Can you get your hands on any of the DACs that I listed - these are the ones which have already been used in listening tests & found to be revealing of differences?
What does Pano's system use as a DAC?
Pano, I know the SS Tabor - it's built using his CCS module stages as building blocks emulating a Pentode - I've partially built one as I use his CCS & Swenson regulators in my tube equipment but it requires some mammoth heatsinks for heat dissipation - just haven't gotten around to acquiring these..
Whatever is handy or I'm working on at the moment. Could be DCX, various Crystal, BB or ESS chips. They all sound a bit different. But one thing is sure, almost all use a transformer output stage. It's what I like.
Have you any ESS implementations at the moment?Whatever is handy or I'm working on at the moment. Could be DCX, various Crystal, BB or ESS chips.
Nothing wrong with that, I like transformers too!They all sound a bit different. But one thing is sure, almost all use a transformer output stage. It's what I like.
Sy, can you layout the intended test set-up for me? What DAC will the Hiface feed into? Where will the analogue out of this DAC be fed? What analysis software, etc. I would like to hear some details, please.
Sy,
How about you instead show the results of test that will appropriate and meaningful in the context, e.g. a J-Test?
Ciao T
One other offer I'll make to you
Ciao T
SY, I did ask for this on the other thread, if you remember - some verification that your tests are appropriate to the DUT.
Folks, as a POST SCRIPVM,
I would probably recommend using a Manufacturers eval board with documented jitter performance (e.g. the Cirrus Logic CS4398 demo fixture) and using a non ASRC based receiver for measuring the analogue output.
If an AP2 is too hard to come by, some external sound cards have converters with reasonable resolution and their clock systems can be modified (stock not very good) to allow reasonably low levels of jitter to be measured (still not patch on an AP2, but it will serve), the EMU1616M is one example.
As said, my view on listening tests with a small N is that they are statistically speaking completely non-significant, so I would probably not bother. The minimum I accept for "good enough for internal use" has an N of around 50 and at least three experienced listeners...
Ciao T
Ciao T
The effects of jitter on analog outputs of DACs are well known and characterized. Generally, it's harmonic distortion and sidebands, but whatever it is, the DAC/ADCs I use are far more than capable of measuring to even the most ridiculously postulated hearing threshold, as you can see by the basic measurement results.
With music as a source and Diffmaker, we can slice things even finer; it's a wonderful tool.
Can the modified Hiface outperform $20 worth of Chinese PCB where the rubber meets the road- the analog signal that becomes the music? Stay tuned...
What would the signal path be in this test?
USB out > interface > DAC > M-Audio analog inputs?
Yes, but I'll probably move things around as well since the M-Audio has full spdif input capabilities. It might even be worth seeing if my level shifter has any effect when used with the attenuator.
That little perfboard unit I had between the USB adapter and the DCX. Takes the signal to AES/EBU levels. The resistors can easily be changed to give any output source impedance or any input impedance, and it has galvanic isolation.
I have a M-Audio Firewire 610 and a M-Audio 0404 USB that you could borrow SY. I still haven't gotten the GPIB working right on my HP 8903A but soon enough I'll have that arrow in my quiver..
Not expensive enough to get Audiophile Approval. 😀 The 0404 is really pretty much the same thing as I'm using, though more channels and a Firewire interface. But hey, I'm around this weekend if you want to join in the fun.😀
[snip]Reviews were done using PASS D1 DIY DAC, Buffalo DAC, Audiosector NOS DAC, Audio-gd DAC19 DSP, PS Audio PerfectWave DAC
End-users have used a wide range of DACS - some listed here: Hegel HD 10 DAC, Chevron Audio Paradox 8i dac, Beresford 7520 DAC, Abrahamsen V6 DAC, lots more to list.
I have used various implementations of the Sabre DACs - the Buffalo & AckoDAC[snip]
jkeny, to be honest, if I see that list of wildly performance differing DACs, its not very inspiring to me. Either the effect is so huge that even the crappiest DAC reveals it (and then SY is totally in the clear) or we need to wonder how well controlled all those 'tests' really were. Nothing personally, but you may want to know how this comes across.
jan didden
- Digital Source
- RF Attenuators = Jitter Reducers
