• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
Again, please read carefully:
"Using 2 separate ladders for each channel (one for the positive and one for the negative rails, that's the sign magnitude notation), you can add 1 bit of precision, to reach 14 bit."
So with sign magnitude notation you add 1 bit of accuracy (or monotonicity if you want) but the math is the same.
Please, take a look at R2R DAC INL and DNL.
But if you are so sure, you shouldn't had any difficult to mathematically demonstrate what you are claiming.
You can calculate the THD using a spreadsheet.
The DAM1021 ladder schematic could help you to do the math.
Soekris uses 0.01-0.02% resistors,
so in a pure R2R DAC that gives about 13-14bit precision (1/2^13=0.00012*100=0.012%)
13 bit has SNR of about 78dB
Still Soekris manages to get about -110db on the analog output, which is 18bit.
This should be impossible according to you reasoning with 0.01 resistors.
This extra resolution that you get is due to the sign magnitude design.
I'm waiting for an explanation of your claim that the DAM1021 with 0.01-0.02 resistors should only have 13bit 78db resolution, bust still manages 17bit 100db
Déjà vu.
The topic stuck so if I may..
Maybe because of 64 times oversampling which gives additional 3 bits. 14+3=17
That’s why I ask Soren about dam1021 rev.7 FIR2 and shift registers sample rate change.
Oversampling - Wikipedia
I have a Soekris 1321 DAC that is not making output. I thought I'd try updating the firmware. The micromanager on my DAC is 1.14 and I believe current is 1.20. When I try to update using the version from the Soekris website, I am able to download but get "Invalid Image" error when attempting to update. Any suggestions? Thanks.
Hey Søren! I am really keen to get my hands on one of the new rev. 7 boards, but the US/Canada web store has not had stock for quite some time. Any word on when they will be available to purchase?
Thanks so much!
I had rev7 boards, and the firmware is done. But to reduce risk I didn't make that many in the first series, and then a couple of my volume customers needed boards and emptied my stock....
I'm about to make the next production series, and this time there should be be enough for everybody. Shipping in three weeks, keep an eye on the soekris website....
But it is also getting harder to source parts, as everybody should know now there is a worldwide semiconductor shortage, official Xilinx leadtime for the Spartan-6 is now at 53 weeks !!!
It's more to do with the oversampling. Same idea behind sigma-delta, just applied differently. Also, there's THD, IMD, SNR, INL, DNL, that all contribute to ENOB. I assume the last two aren't too great for this design, but for audio (no DC levels), that's no concern.
Thanks! Just added another 1500uf polymer cap to the Vin. Yes, this does sound better!
You're right about the shift registers, of course. Didn't like what any additional caps did there. Maybe replacing the ceramic caps with bigger ones will work.
I got a rev 4 and ordered some polymer caps today. So, to confirm. Danny_66 showed how to easily place them on the 3,3V Vout, on J9. https://www.diyaudio.com/forums/ven...magnitude-24-bit-384-khz-482.html#post6496437
Then there is also the cap on Vin, on J2. But where exactly have you connected this? On J2 Pin 1, 4, 7 and 10 are GND, pin 2 is PWR A-, 3 is PWR A+, 5 is PWR -5V, 6 is PWR +5V, 8 is PWR 3.3V and 9 is PWR 1.2V. I am quite sure it is to PWR A+ (and gnd)?
many thanks, Erik
