Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
So it's a source of THD from the R2R architecture that we can do nothing about? But of course if Vref impedance is 0 then current draw doesn't matter.
It would be so exciting if Vref circuitry doesn't matter and we get to claim perfection on the dam dacs. But on the other hand, if it does make a difference, it would be an opportunity for us to break new grounds in our understanding of psychoacoustics, and perhaps be one step closer to understanding the R2R/DS mystery.
ynmichael could the fact that upsampling to the max sampling rate, effectively reducing the delays to the minimum more consistently each lock, be the source of the improved quality overall? I always thought at some point the delay was there and noticeable but it seemed hit or miss, might be worth getting a 1941 afterall just to have something to test against. I too have asked Soren for a sync solution in the past, even if it meant tapping an unconnected pin to do so, avoiding compatibility breakage.
You can definitely hear the difference in ABX, but it’s probably a slight shift in localization than anything else. I really hope Soren can take a little time to enable the sync function and fix the delay problem which as we’re starting to see is non-negligible in some tests.
I was wondering that myself, the delay should theoretically should only be the difference in the clock generator phase if there is an exact constant that the code is referencing to maintain an exact fifo buffer length so no 2 boards would be different if fed the same signal. When Soren says they track to x amount of one another, he doesn't elaborate on how the lock is maintained and if there is a target buffer length to maintain once lock is obtained and synced. The clock from a good usb-i2s converter should be sufficient to keep both boards in near perfect sync without worrying about randomized delay on a per lock basis.
EDIT: Reposted for clarity.
I have bought dam1021 v5 very recently. Should I implement the vref mod. I don't have any experience on this. As I have gone through various posts, I found that e 12 pieces of 1000uf 16v capacitor can be used for vref mod. I have 1000 uf 16v capacitor (ESR 7), can I use those? Is it all that I should do for vref mod. Need your kind suggestions.
Those seem to be fine caps. Put them on and you should hear a big difference. But before you do that, if you can record the outputs and post them, many people including me will be very grateful.
Soren, if you use the shift register buffer, maybe you should get rid of the opamp Voltage regulator too. I think TotalDAC might be using shunt supplies in new versions which is why there’s no caps - there is no need since good shunt supply such as UltraBiB have extremely low impedance over all frequency. Maybe in 5 years ;)
Your picture revealed that Soren improved the vref circuit on rev5 to match his commercial products. They dont have the load resistors any more. Can someone with an actual background in electrical engineering explain what benefits it might have? And whether it’s possible to mod on earlier revisions? :)
Gosh I feel like if I ever need a second DAC, I might want to just get the TotalDAC... the price is a bit steeper than it needs to be though...
Yes, add them through the vias,
for the leads that go through the vias: don't cut them short, so you can use those leads to add some additional caps on the backside.
Also add a cap for the clock, you can also use the available vias, see this post.
Thanks for the suggestion, is it the place where I should put a cap for clock? Can you please give me some more detail, what cap should I use, volt, mfd and orientation.
Why would you want to add a cap, I assume to the clock? There’s really no point. Clock jitter is <1ps, fpga jitter is hundreds of times that.
Source: The Soekris R-2R DAC: Technical Details | H i F i D U I N O
It is a pretty hefty regulator. And it seems the only 3.3v regulator on the board. It must also supply 3.3V to:
3.3V need of the FPGA
Clean side of signal isolators
SPDIF LVDS receivers
Microprocessor
Flash memory
Other components (like the shift registers?)
Good thing it is implemented next to the clock of all places.
