• The Vendor's Bazaar forum is for commercial offers and transactions. Only unmoderated members can post here.
Reference DAC Module - Discrete R-2R Sign Magnitude 24 bit 384 KHz
Hi i have full batery powered 1021 by 3,3v nominal lifepo4 bateries. Board with no stock stabilizers. I was wondering about 1021 clock power supply. One frequency clock need 3.3v but linear, frozen 3.3v need to have that desired frequency. what is on 1021 clock? I have powered him by lifepo4 battery and wee all know that fulll charged bettery have 3.6v , not charged can have 3v. Did this is problem with desirded 1021 frequency in clock?
This one is for the brave. And for those not shy to use a desoldering station 😛
hi there everybody,
do you know which serial numbers the different revisions of the dam1021 have?
rev2 starts with ser. number xxx
rev3 ...
i dont want to modify the board itself, so i am not so sure, if i should invest in rev5, or get e.g. a used board from rev2. (soundwise...)
thanks for your help!
I have a simple question:
I still have two 1021 boards in my basement. I have built and modified the DAM1941 when it came out and listen to it and I am very satisfied.
There are some experiments though where I do not want to risk the main DAC (1941) and try this maybe with the 1021 instead...
Is the 1021 capable to get to the same level as the 1941 ?
Is there a summary of mods as it looks as of today (220 pages is a bit too much to read...) ? Air de-soldering or air-soldering is no problem.
Thanks for any hints !
Hi, my 1021 is rev5.
Right channel had distorting yesterday. I measured positive side only 3.5Vref.
And I try it again today. It turn to 3.9x Vref. Very close to 4V. But sounds still have a little distorting....
Dose someone have know what happen with my 1021? How can I solve it?
I think I find the problem. If I do the Cap Mod's, Vref+ will drop down slowly. When I remove Cap. It will be ok.
But I don't Know why does it caused.😕
