A 60 Hz motor used with a lower frequency is less efficient. It is the
same as with a mains transformer. I can not recommend using a
dedicated 60 Hz motor at 50 Hz.
Actually the manufacturer should have been even a 50Hz version of the motor in image No 3 from post # 13.
HelloYes, thank you very much in advance.
Check post #14 the ordering address.
Sorry for terrible delay.
Here are belt dimensions:
d=2mm
length(in working position) 950mm
length 915mm
Hope, it would help.
Once again, sorry for delay.
thank you. Maybe this one will be good:Hello
d=2mm
length 915mm
https://www.thakker.eu/riemen/auf-mass/round-belt-290-0-x-2-0-circumference-911-mm/a-373/
That's the one, I think. Pretty close at least.thank you. Maybe this one will be good:
But let me tell you this.
Friend of mine has Transrotor TT. And after he installed the new belt wow and flatter increased up to 0.20%.
Not sure was it Thakker or not, but there is a fact.
The 911 mm Thakker belt provide similar results, i. e. lower value for circumference is necessary for lower slip.That's the one, I think. Pretty close at least.
Measuring the length (whole circumference in stretched condition) according method number 2. under
https://vacationvinyl.com/how-to-me...d is one of,measure its length in millimeters.
i. e. motor pulley and platter outer diameter together provides a length value of 923mm.
I guess, this means a circumference below 900 mm (maybe 850 mm).
I ask via email the value for this belts and look forward for the replies:
https://www.analogueseduction.net/p...t-xperience-replacement-drive-belt-round.html
https://www.lpgear.com/product/MOTHKANOOT.html
what difference is between red and black belt (same size - go to the attached images) ?
Best thanks for an information
3470390-d1472ef5-oak-audio-turntable-british-vintage-80s-with-audio-technica-cartridge.jpg66.8 KB · Views: 72
3470391-de5bcc02-oak-audio-turntable-british-vintage-80s-with-audio-technica-cartridge.jpg60.3 KB · Views: 67
3470389-0bee7983-oak-audio-turntable-british-vintage-80s-with-audio-technica-cartridge.jpg65.8 KB · Views: 81
3470388-d94e79be-oak-audio-turntable-british-vintage-80s-with-audio-technica-cartridge.jpg43.2 KB · Views: 70
3470387-202bc1b2-oak-audio-turntable-british-vintage-80s-with-audio-technica-cartridge.jpg80.8 KB · Views: 70
3470386-977e2825-oak-audio-turntable-british-vintage-80s-with-audio-technica-cartridge.jpg76.7 KB · Views: 78
2203459-b4edff73-moth-kanoot-rega-rb-300-tonearm-w-grado-zt-cartridge-with-audio-technica-leve...jpg80.6 KB · Views: 76
2203473-6127695d-moth-kanoot-rega-rb-300-tonearm-w-grado-zt-cartridge-with-audio-technica-leve...jpg91.7 KB · Views: 74
2203474-e3b1dc90-moth-kanoot-rega-rb-300-tonearm-w-grado-zt-cartridge-with-audio-technica-leve...jpg90.8 KB · Views: 78
2203475-f1be598c-moth-kanoot-rega-rb-300-tonearm-w-grado-zt-cartridge-with-audio-technica-leve...jpg75.4 KB · Views: 79
2203477-6294a28d-moth-kanoot-rega-rb-300-tonearm-w-grado-zt-cartridge-with-audio-technica-leve...jpg73 KB · Views: 75
2203476-7a63d9c3-moth-kanoot-rega-rb-300-tonearm-w-grado-zt-cartridge-with-audio-technica-leve...jpg130.1 KB · Views: 73
Are there a difference between the turntables "MOTH SUPER OAK", "OAK Audio" and Moth OAK ?
According the attached images - found under canuckaudiomart (first both) and facebook (third image) and closed ebay auction (last image) this turntables are identical models, but I am not absolutely sure.
Now I can confirm definitely, that this belt works perfect on Moth' KanootThat's the one, I think. Pretty close at least.
and cheaper than from this supplier in the U.S.:
- Analogue Source
- Record Player/Turntable Kanoot from Moth Group - Motor Pulley for 50 Hz needed
