Real or fake PCM63?
Hello, a good friend of mine oredered and recently recieved a pair of PCM63 - Y grade. Somewhere in the forum there was discussion about this not well known grade. These devices put into the contactors instead of my own pair of K grades sound very different and for sure not better. I took a detailed look at them, here they are:
What made me doubt if they might be fake is the place of "Y" grade marking - not where they put J or K, and most - the pins are so clean, shining and scratchless as they had not passed production test and had not been put in a contactor.
I wonder what you might say looking at this chips...
Maybe the Y lasered / etched (?) are produced to meet specs while K stamped are selected from production.
Anyway I tested K and K2 with analyzer and they were nothing special...
Also they are not tested in ordinary sockets that make scratches, ever noted new chips have pins not 90° ?
Dr.H,
thanks for this. I did not see this topic until your post came on the "Pcm63-y?" thread.
beauty_devine;
beauty_divine said:
sound very different and for sure not better. [/B ]
This is interesting: Please let us know what is the different in sound; can you describe it?
What made me doubt if they might be fake is the place of "Y" grade marking - not where they put J or K, and most - the pins are so clean, shining... [/B ]
I was the one who started the subject, so I see myself somehow responsible...
First, do note that I got similar "Y" Chips, and only the dates are different: 0323 E9 027.
It is also BB Japan, same colours which are engraved on the Chip.
Like Bernhard I assume that this come from some special series.
Can it be at all fake? I wonder, because if it is not PCM63, what can it be??
The really sad thing here is that you don’t like what you hear. So please give some more info. By the way, which configuration you are using?
See also the other thread: There is a lot of info about it. http://www.diyaudio.com/forums/showthread.php?s=&threadid=116664&perpage=25&pagenumber=1
IY.
Re: Re: Real or fake PCM63?
What matters most is the sound and the sound is bad :-(
I've got two pairs of 63-K, one made in Japan, the other in the Philipines. There is no noticeable difference between them.
On top of this, a friend of mine has external DAC Parasound 1000 that originally comes with pair of 63-J, and replaced with the mentioned 63-K the DAC sounds definitely better. However this pair of 63-Y has nothing to do with the sound of the K's.
Whether the Ks are something special or not I don't know. Measured they simply meet the spec especially in the low level signal range, where they sound noticeably better then PCM58.
What I see on the picture of your DAC there is "-" sign before the grade letter "Y". On my friend's DACs this is not there. That seems inappropriate.
A friend of the Bulgarian audiophile society said that the russians produce fake 63's that even can work without -5Vdigital supply :whazzat: I really do not know what to think about this issue....
Hm, interesting, I had heard about fake chips but did not believe I would see one. I am not sure if this is fake but I have a friend that said the PCM63 were made in Japan up to 98 and then Philippines and then Korea, there is no way it was made in 2004 as designated on the chip... Or may be it was a secret production? :whazzat: Anyway, looking at the two pictures there are a differences - apart form the unusual place of the Y, there is a difference in the signature of engraving and also the "-". Is it from one and the same source?
Fake or not Fake
Hi beauty_divine & Ivan Petrov,
The Chips looks indeed slightly different, just as you described!
It will be interesting to get an answer from any of our Japanese diyaudio friends, who might know the people from BB Japan. May be they will answer this question about the production mystery. My Chips are from 2003…
I would have ask you to send them to me for a try & examination – however I don’t have the possibility to do so, as since 1 month both my PCM63P-Y Chips are mounted directly on the PCB.
Before mounting them however, I have been to my good friend, the Digital Specialist Stephan Horwege http://www.hoer-wege.de/ and showed him the chips. We listened to them in comparison to K (Korea), K (Phl) and also the Monarchy Audio PCM1704-UK Adaptor Replacement. There was no question which Chip is the better one, and since then they are peacefully mounted on the PCM.
Was your Chip faked by somebody? It is quite hard to believe: How one can fake this complicated kind of chip? Moreover – it demands a tremendously amount of affords for a relatively small market-segment.
I would think that something else in your HiFi chain is responsible for this: You will have to check this carefully.
As for the sound-changes: Going from “J” to “K” is indeed easy: One hear that the K does not scream like the J. Now – going from K to Y – you should hear that the sound changes are going in different directions at once: It has a lot of depth, the sound stage is hugh, the instrument's sound is becoming full (try listen to a classic instrument like Violin or Clarinet or even Flute). Tell me please if the sound at least changes in this direction. If yes, see where in your HiFi system you were trying before to compensate for the "J" harsh character; may be now it is sounding to “heavy” , “bold” and “not transparent” ?
Parasound DAC 1000
beauty_devine,
the Parasound DAC 1000 is using the somehow old SM 5813 Digital Filter. You should try to put your hand on the DF-NPC-13 Adaptor from Audiotuning - it is a direct replacement, and it has on it the BB DF1704 Digital Filter.
My DAC has such a DF1704, configured to 20 bit out + "Slow": It works magnificently with the PCM63P-Y. However, if the configuration on the filter (DF1704) is on “High”, the sound is quite bad.
There seems to be odd things going on in the world of PCM63's....
digchip.com is listing pcm63's with date codes of 04,05 and '07. There are 17,000 '07 dated coded pcm63 listed as available. How is this possible for a chip that was listed as obsolete/OOP by 2003?
Things are getting pretty stupid....
this site is listing pcm63-k (new as used in space shuttle Endeavour) at 150USD EACH.
http://diyaudio.org.ua/forum/topic242.html
I've ended up with '04 DC 63P Y's as shown in the pic at the start of this thread. Unfortunately I can't compare with any "know good" PCM63's except to say they are far better than pcm63k's A'af was selling.
cheers
Paul
Monarchy
This is a factory (piggy-back) Monarchy Audio Chip, I think they still can supply PCM63 K for reasonable price.
Arne K
Re: Parasound DAC 1000
irgendjemand said:
beauty_devine,
The difference between J and K grades I checked on the Parasound with SM5813 DF.
The K to Y grades I tried on my CDP equipped with SM5847, where K sounds much better then the suspected to be fake Y chips. To my opinion 5847 is much better than 5813, so the example must be correct 🙄
Re: Fake or not?
beauty_divine,
Paul has just the same chips as you have, and it seemed to sound really OK for him. 😕
My "Y"s are slightly different, but they also has the same unusual gold-colour markings; I am wondering ?
Now something even more strange: In all the original BB Japan PCM63 Chips (and I visually inspected ALL Japan - P, J, K, K2 and Y, chips), the letters "PCM" are printed exactly under the big “BB” letters. This is so also in your case, however not in mine (!), so if something is faked, my "Y"s have a good chance to be the faked ones... :headshot:
On the contrary, when I got the Chips, they looked just like I would expect a new-old-stock to be: The legs have been perfectly straight & symmetric. It was quite hard to put them in the sockets, and I had to "form" them correctly (!).
I would have thought that someone indeed re-engraved / refurbished them so that they will look new. However, if the were used, I would have noticed it on the legs, I am pretty sure. :smash:
My assumption: The chips are original BB, new-old-stock. However, for some unknown reason, someone have marked them new. It might have some criminal energy behind it or not.
I assume that while marking the Chips, there have been also some selection/identifications mistakes or confusion.
Note that there are also "K" and "K2" Chips on the market (also from A'AF) which are gold coloured; all have new dates (2002, 2003, etc). I can tell you for sure that I compared a gold-coloured "K" with a regular "K" – and there have been no different in sound - both have been a real "K"! My own experience shows that the Type which is written on the Chip is normaly correct. My "Y"s are sounding excellent.
What can you do now? If you bought them from A’AF, just send them back to him and ask for a replacement. Ask him also for the source for the chips. He is known as reliable, and usually he will react fast. Please keep me/us informed.
I checked with Monarchy Audio several months ago and they have no (zero) stock of the PCM63 in any flavor. Their website is out of date.
We've seen pics of the stamped K chips and that procedure is well known. I haven't seen any pics of a known good Y grade chip. Why should we assume that the Y's are stamped in the same way? We don't even know what the Y grade was. It's well documented that K's were selected from normal production runs but is there any information to suggest that this was the same for the Y's?
Who is to say they are a "better" chip than the K's when there is no Burr-Brown data available.
and:
the "Y" IS on the BB Date Sheet, Page 11, "PACKAGE OPTION ADDENDUM". It is listed there. I copy it for you here (the printing format will changed a bit):
Orderable Device Status (1) Package,Type, Package, Drawing, Pins, Package, Qty, Eco Plan (2) Lead/Ball Finish MSL Peak Temp (3)
PCM63P OBSOLETE PDIP NTD 28 TBD Call TI Call TI
PCM63P-1 OBSOLETE PDIP NTD 28 TBD Call TI Call TI
PCM63P-J OBSOLETE PDIP NTD 28 TBD Call TI Call TI
PCM63P-K OBSOLETE PDIP NTD 28 TBD Call TI Call TI
PCM63P-K-2 OBSOLETE PDIP NTD 28 TBD Call TI Call TI
PCM63P-Y OBSOLETE PDIP NTD 28 TBD Call TI Call TI
IY
IY,
Like I said there is no information - apart from the fact it was available.
Have you seen specs? There are none in the datasheet and google doesn't reveal anything. At least with the K2 you can find information that indicates that they were used in a high-end pro Sony CD mastering device.
thanks for posting the pics. where have these come from?
cheers
Paul
Note: As far as I'm aware A'af never represented the PCM63K as being a PCM63P-K he only ever claimed that they were a military grade version PCM63. They were priced far lower than the PCM63P-K's he was selling.
Pcm63p-y???
Well, I do remember me starting once this "Y" topic with the following question (on the "Pcm63p-y???" thread):
"Has anybody ever HEARD the sound of the Burr Brown PCM63P-Y in real life? According to the mythology, this "Y" selection grade should have been the absolute-best of all PCM63’s; however, there is Zero information about this particular PCM63P in the "Y" Version on the Internet."
No any specifications came until now either… At least it SOUNDS.
IY
