Question about soldering
I understand the preference for leaded solders which many forum members advocate for. Still, lead is a nasty toxin and the less of it in our (or your) environment the better.
If you choose the lead-free path the best advice is flux and lots of it. Even with flux core solder additional flux helps tremendously. If you rework or touch up a joint add more flux first. Use solder wick to remove excess solder from joints so that the filets look proper (the same profile as with leaded solder).
You may want to take on surface mount designs in the future. Many components are now only available in surface mount packaging and this trend will certainly continue. If you decide to tackle surface mount designs you should invest in a good stereo microscope. No serious commercial lab would try to do surface mount without the proper optical aids. It’s a fascinating world down there when you can see it clearly!
The key to lead-free soldering is to use a eutectic solder formulation, i.e. a SAC alloy (tin/silver/copper). The other sort (without the 4% silver) is only suitable for machine use. Definitely second the comment about flux - the higher temperature leads to more oxide formation and flux reduces oxides.
Nearly all new components are surface mount only, and have been for ages. Many times the only through-hole components on a commercial board are connectors where the extra mechanical strength is needed, or heavy/bulky components for the same reason.
Reactions: Cyberpup
350 is where I set mine. What set me only buying a thermostatically-controlled soldering iron with temperature adjustment was lifting a pad on a Fender Blues Junior PC board. Thankfully it was a structural pad and hole for holding down a pot that lifted and not a circuit pad and hole but that scared me.
It depends on the power and regulation of the iron. Also on the copper thickness and design elements like polygons. With 100W iron I set around 320C for most of the work. Quality leaded solder has melting temp at around 190C, so there is big reserve.
No. Sale of solder with lead content to consumers is banned in EU and EEA since March 2018. The ban is not part of RoHS directive.
https://ila-reach.org/2018/01/new-r...g-requirements-affect-lead-from-march-1-2018/
Oops! Did I miss something, where I have to put in SIM card? I'm kidding🙂.
As a child, I read whatever I laid my hands on. Man, man... this is EU law... Are you lost? It's not a problem. Try you again, I'll give you a hint. Let's start with the obvious:
https://de.farnell.com/stannol/hs10-2510-0-7mm-500g/l-tdraht-362flux-0-71mm-500g/dp/817508
In case it's not obvious - I'm just trying to help.
To be continued. With pictures.
Anyway for smoke absorbers what do folks use?
Never used it, and personally I wouldn't trust too much the filtering capabilities of what seems like little more than a toy and in my opinion would only get in the way of your work.
In my opinion, in the amateur field an open window is much more effective and safe for proper ventilation of the environment in which you work.
здравей
Не искам да се намесвам в разговора ви, но бих искал да отбележа, че продуктът, който сте линкнали, не съдържа олово.🙂
Всички ние тук, дори някои повече от други, го правим тук, за да дадем положителен принос.😉
1- ?? И какво съдържа? Единият от нас е луд /другият съм аз/. Колко добър си в спора и дебатите? Ще загубите 🙂.
2- Тези смели заключения оставят някои тревожни проблеми неразрешени. №48, №51 - как ви се струва? Слушам те внимателно 🙂🙂.
Logon, witty answer, but didn't sound convincing. Is there anything else I should know? OK. I wonder what this means - ''workaround'' #48? Probably ''for those who want to get around the law - village tricks for beginners?'' I look, read aloud and can't believe my ears. Enough nonsense. We've become the laughing stock of the world! Logon Logon, listen carefully and take notes: How to read EU legislation? Ask America's top distributors. The devil is in the details, the truth lies between the lines. So here's the solution /in my experience/: I bought a soldering wire about 1 month ago from DigiKey /Kester 24-6337-7402, €147/. Do DigiKey know the laws, our/EU/laws? Don't doubt. They know what they're doing, trust me. Incoterms DDP, free shipping and so on - the perfect distributor. I've said it before, and I'll say it again: Thank you USA!!!
I've spent the better part of two decades /as a hobbyist/ using solder STANNOL-Sn60Pb38Cu2. Excellent product, but it is no longer produced.
I hope you find this information helpful /the EU members/.
@BATE VANKO
See, I believe that everyone has their own needs and everyone disposes of their own time and money as they wish.
Thank you for sharing your experience and I'm sure that what you say makes sense to you, but what I want to highlight is the fact that as you have already been told by more than one other member in EU there is a ban on selling lead-containing solder alloys to non-professional users.
How will they put this into practice and distinguish who is an amateur from who is a professional?
I don't know and I don't care to know.
Did I perhaps say that I am tearing my clothes off because I can't find what I want at the price I want?
No, I didn't say that.
There are such a huge amount of (good) products out there that everyone is spoiled for choice: you are happy with Stannol (and I have some too) I got along well with Cardas and now I get along well with a (good) 60/40 that costs a quarter of the price of Cardas. 😍
P. S.: In my opinion, the fact that even things prohibited for reasons of public health can be "easily" purchased does not exempt anyone from their responsibilities, neither the sellers, nor the popularizers, nor the buyers.
And since this is an international public forum (which must be written in English 😉) that's the only reason I'm not going to share the "workaround" I mentioned and that you still seem so curious about. 🙂
#74: ''And since this is an international public forum (which must be written in English ) that's the only reason I'm not going to share the "workaround" I mentioned and that you still seem so curious about.''
Wasting my time... Logon, please check #48 before bothering me with your nonsense. Of course it's not true! That is a justification for some of the things you written.
The reason /in englisch/: #48 - ''THE GRAVY TRAIN COULD STOP''. Logon, sometimes it's better to stay silent. That's why: ''GRAVY TRAIN'' /slang/ - ''A position in which a person or group receives excessive and unjustified money or advandages with little or no effort.''
This is the truth. Does that tend to create a more collegial? You need to ask yourself this. Anyway, let's move on.
So, lead vs. lead free solder? 180°C vs. 220°C? Dunno - everyone will have to decide for themselves. About ''Buying lead solder'' - I will explain that in explicit, simple, concise and unambiguous detail to make sure it is fully understood:
1. Country selection - USA
2. Distibutor selection - USA /a wide celection of products - lead solder/, in my case DigiKey
3. Order - Incoterms DDP, DDP, DDP, 1000xDDP!!
4. Ship to address
5. CUSTOMS CONTROL: Let me be clear - customs are involved in the implementation and enfocement of EU legislation on inport from non - EU countries. IT'S NOT EASY!
6. Deliver to address
7. Hooray and... don't forget to say ''Thank you BATE VANKO''. I'm joking.
BUT! We live in interesting times and everything could change tommorow. The international situation...
What you write is unreadable.
First of all, you are unnecessarily mocking and sometimes insulting all those who claim that lead is banned in Europe and at the same time you are demonstrating that for you respecting the rules means nothing.
Needless to say, I won't answer your nonsense anymore.
Secondly, no one complained that lead alloy was no longer available at all for purchase in the EU, but only that the EU had banned it (a true fact that is not in dispute).
Thirdly, what you seem to want to demonstrate is only that you are so smart that you can even get lead soldering what is banned by European regulation: did anyone ask you that?
No.
So, what the hell do you still want? 🙄
You can use a small fan to blow clean air towards your face/fumes away from it. But a simple trick I've used since I started soldering is to simply hold my breath, wait for the smoke to clear or blow away the last whisps.
Rosin fumes are an irritant and holding your breath doesn't prevent them getting in your eyes... Exposure to irritants sometimes leads to allergies developing, best to avoid as much as possible really.
And you are right, however if the room is not (sufficiently) ventilated the unhealthy air will only be moved (and obviously cooled), but will remain in the room.
As a matter of fact, if you notice that, commercial extractors, even amateur ones, are equipped with a filter.
Edit to add: However, I don't believe too much in their effectiveness, but I could be wrong...
Yes, a poorly ventilated room is problematic. I open windows in the house so as to create a breeze in the room - Athens weather permits this most of the time.
But I have tried both : windows open or closed, sucking air away from the soldering area is much more effective (and practical) than blowing air to your face. Besides, soldering fumes tend to gradually stay on the table as they cool down, and can't be removed very effectively if not sucked away.
