Here's a schematic of the XO for the Heybrook HB2's -- the woofer for this one was destroyed by too much teenage activity so it is in the woofer replacement facility -- why is R1, C2, L3 connected to the tweeter "+" ? when I simmed it I note that it "shelves" the response. The tweeter seems to be the standard, government issue Audax 1"
Here's what the actual response into a resistive load looks like:
No, I am not kidding:
Hmmmm, here's a pair of phase-gain plots of the Woofer section of the Heybrook XO -- the first with R1, C2, L3 connected as illustrated, the second with the network disconnected:
I agree with sreten that it looks completely pointless to have them connected as in the diagram. It looks as if someone has misinterpreted a circuit diagram (twofold, first the 560 ohms, then where they are connected).
Is the diagram an original heybrook diagram or is it drawn from the actual components in the box? Are the components connected the same way in both speakers?
Easy there guys! I think you should be a little slower to assume that jackinnj cant even follow some wires! This circuit might not be familiar to you, but it obviously does something and I think jackinnj's idea here was to spark a conversation about it, not get accused of being stupid.
I mocked up the crossover both ways and the additional components are very interesting to me. They seem to be making the electrical phase more symetrical and closer to the a standard 4th order target (i cant tell which one). I am still new to this so I am not sure if I am even on the right track, but at least I give my fellow DIYers the benifit of the doubt .
-Chad
-Chad
As far as I'm concerned I can't see any audible point of the circuit.
If R should = 560R then the type of inductor is totally wrong.
If you redraw the circuit to look like a normal crossover it
looks like a blatant wiring and a component selection error.
The question was have they made a mistake, the answer IMO is yes.
Fc of the circuit is 1950Hz, which could easily be the tweeter Fs.
In that case it shoulds in parallel with the tweeter, R = 5.6 R.
Its also possible at 2K its there to control a bass unit resonance,
or shape the response. In that case it shoulds in parallel with the
bass unit, but R ? who knows ? 5.6R is the place to start.
But usually the latter is a series circuit (for good reasons), and
as the tweeter has a zobel my money is on the former option.
/sreten.
Are both speakers the same as Svante asked ? (probably are)
/sreten.
ch83575 said:Easy there guys! I think you should be a little slower to assume that jackinnj cant even follow some wires! This circuit might not be familiar to you, but it obviously does something and I think jackinnj's idea here was to spark a conversation about it, not get accused of being stupid.
-Chad
Hmmm.......
The only person jumping to assumptions round here is you.
/sreten.
The fact that it doesn't make sense as it is, and the fact that the circuit would make sense if 560R was replaced by 5R6 and if the circuit was connected in parallel with the tweeter, makes me think that it was originally intended for something else than it does now.
Humbly and without calling anyone stupid.
Adding a resistor that is 100 times the impedance level of the rest of the circuit can only be expected to change the current by 1 % or so. The differences in phase and amplitude as can be seen in the simulations all occur where the amplitude is low and doesn't matter much.
Svante said:Adding a resistor that is 100 times the impedance level of the rest of the circuit can only be expected to change the current by 1 % or so. The differences in phase and amplitude as can be seen in the simulations all occur where the amplitude is low and doesn't matter much.
Without accusing anybody of anything (which was probably out of line and I apologize) is 1% really of no consiquence at all? It seems to me that differences in the DRC of the bass inductor can account of as little as 1% or 2% of the speaker impedance and people make quite a big deal over that.
I guess I just always error on the "maybe they know something I dont" side (of course I know much less than most of you about this subject so perhapse that would explain it ) instead of assuming that the product was produced or designed "wrong". Is there no way this was an intended addition in the crossover?
-Chad
Ok... now sombody will have to do some more explaining for me to understand. Here is the GD of the tweeter (woofer did not change significantly with the circuit):
The one with more group delay in the lower frequencies (red) is WITH the enigma circuit in place and the lower one (green) is without. Is this like an electrical offset for the tweeter (instead of physicaly offseting them)? Or am I missing the boat again? Perhapse we can actualy figure this out now .
-Chad
-Chad
Heybrook was a small firm and probably outsourced manafacturing.
A lot of the smaller companies on the way of going out of business
took some severe liberties with QC and manafacturing standards.
One company I know had the speakers put together by the people
building the boxes, who knew absolutely nothing about electronics.
I suspect something similar.
But 1.9khz is typically twice the typical Fs of that tweeter ......
One thing for sure the Audax does have a large resonant peak,
which due to ferrofluid you don't see so often nowadays.
/sreten.
http://www.audax.fr/audaxdoc.htm
P.S. I'm also assuming those circuit simulations are garbage,
whats a standard 4th order target got to do with 3rd order electrical ?
If your not discussing final acoustic responses your not really discussing anything.
Without full electrical models of the drivers electrical discussions are meaningless.
/sreten.
Well, you're wrong!
My HB2's have the same connection, and I can't understand the logic of it either.
They were designed by Peter Comeau, who until recently worked for Mission, and designed the e-series speakers. He is a very talented designer, all of the early Heybrooks, HB1, HB2, HB3 are excellent speakers.
- Q on Heybrook HB2 XO
