Pure Delight
Added: If you do the Alumnium Sulfate solution be sure to only use glass or plastic containers!! It would dissolve a steel container!
:att'n: Safety warning! If you do this, wear goggles and rubber gloves. Dispose of the aluminum sulfate solution in a safe and ecological manner. And, do use a corrosion and heat-resistant container. Pyrex is ideal.
SY,
Thanks, I will try this one day, as I can remove each part of the sinks without dismanteling all the amplifier.
I have one more question for Nelson:
The output voltage for the finals are 2* 39 volts, no load.
The output voltage of my circuit is only 2*49 volts for the preamp ;
I would need a few more
ie :52.0 volts
in the A75 Power supply schema here after
I read that the differential amplifier had 5.5 gain so 9.1 zener diode gives
5.5 * 9.1 = 50.05 volts
How could I simply modify the circuit gain built with the original values to reach 52 volts ? :smash:
I don't know any thing about diff's
Alain.
Nice work
Looks like a lot of good info on tapping did arise. My experience is similar to others: Good fluid, use a tap only in the same type of metal, the first time you feel it even have a hint of a bind, throw it away. $5 on a tap is much better than the 10 minutes of profanity after it breaks!!!!
Most importantly, though, keep up the good work and get to other projects soon. I like very much the quality of what you've done.
Sandy.
Peter,
>Try to play with R10 (2k2). The simplest way would be adding a parallel trimpot >(100K or so) and see what this does.
I appreciate, my knowledge of diff's and digital circuits is near the grass!! :bawling:
I am here to learn a lot.
>Also, under the load your rails might go lower than "39Volts" so maybe what
>you are getting presently at front end is high enough?
In fact they will because of the 0.5 Ohms 20watts of the CRC's
I just wanted a little more security. and 50/52 volts sounds good to me !}
Thanks.
Alain.
